Rapid Storage Technology
Intel® RST, RAID
2253 Discussions
Intel© Accelerated Storage Manager - Login
FBois2
Estimados
Intento acceder a la interfaz web y me colocando todo tipo de claves y usuarios del computador me da "Access denied. Try Again".
Agradecería cualquier ayuda o tip. Gracias
Lo que necesito hacer es poder configurar y ver detalles del RAID que tengo en el servidor. Si existe alguna otra herramienta para esto igual me serviría.
David_V_Intel
Hello FBois2, Thank you for posting on the Intel ® communities. First, I would like to let you know that we use a translator to understand your situation, this is because the Intel ® communities support is in English. Now, I would like to know the model of server you have, please provide me with the model number so we can assist you further with your situation and have more details of the system in question. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
FBois2
Dear
I just sent you a private message with the server data.
Thanks in advance.
David_V_Intel
Hello FBois2, Thank you for your response. I have checked the information you have provided and in order to get the best assistance it is recommended to get in contact with the manufacturer of your server motherboard. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
