Rapid Storage Technology
Intel® RST, RAID
2248 Discussions
Intel Optane Memory and Storage Management - Notifications
U_Ped
Hi.
I can see Intel® Rapid Storage Technology and Intel® Optane™ Memory applications are end of life and it-is recommended to update to The Intel® Optane™ Memory and Storage Management from Microsoft Store.
However, I cannot get notifications to work. I think it is because Intel Optane Memory and Storage Management is missing in Notifications and actions. How can I enabled notifications?
Wanner_G_Intel
Hello U.Ped,
We would like to provide an update regarding the system notifications of the Intel® Optane™ Memory and Storage Management application.
System notifications are not yet part of the new Intel® Optane™ Memory and Storage Management UI. Please expect this feature to be available in upcoming driver releases.
Wanner G.
n_scott_pearson
Yes, with the transition to DCH drivers, the GUIs are now App Store applications. This change is a requirement being pushed by Microsoft.
Have you scrolled down through the Get notifications from these senders list to verify that notifications are actually enabled for this app?
LeonWaksman
@U.Ped​
See the attached image, showing Intel Optane Memory and Storage Management notifications enabled
Leon
U_Ped
Thanks for answers. I cannot find Intel Optane Memory and Storage Management on the list for notifications. How can I enable notification for this app?
U_Ped
posted a file.
LeonWaksman
  1. There is something wrong in your Windows.
  2. I suggest that you should perform an Repair Windows with an In place upgrade. Using this method you will have Windows reinstalled, with all your data and applications in place. You should start from par. 6 (i.e. use Microsoft Media Creation tool).
  3. For safety reason, perform this repair with Optane disabled.
Leon
U_Ped
I reinstalled Windows, but Intel Optane Memory and Storage Management still not appeared on the list for notifications.
It worked after I forced a notification, example by disable and enable Write-cache buffer flushing in the App.
But I still not think the notification are working perfect. In my setup I am using RAID 1 (2 x 256GB SSD). I have tried to shut down and unplug one of the disks. My RAID is now down, but I don’t get any notification in Windows action center.
Service RstMwService (Intel(R) Storage Middleware Service) are running.
LeonWaksman
I can't help you more since I've no experience in RAID. I'm using the Intel Optane Memory and Storage Management for Optane acceleration. I hope that some body else will give you better advise.
Leon
U_Ped
Wanner_G_Intel
Hello UPede,
We would like to have more information about your system configuration.
Are you still using Intel® RST?
Please provide us with the following reports:
Intel® RST System Report
  1. Open the Intel Rapid Storage Technology user interface (Start > Programs > Intel > Intel® Rapid Storage Technology).
  2. Click the Help icon.
  3. Click the System Report icon.
  4. Click Save.
Intel® System Support Utility (Intel® SSU) report.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
Wanner G.
U_Ped
No, I am not using Intel Rapid Storage Technology user interface, because this software is end of life. So I am using the new Intel Optane Memory and Storage Managemen App instead.
I have sent you a PM with SSU report.
Wanner_G_Intel
Hello U.Ped,
Thank you for your response.
According to the system report, the system configuration you are using is supported, and you should be able to receive notifications when using the Intel® Optane™ Memory and Storage Management application.
Intel® Core™ i5-9500 Processor
BIOS 2606
ROG STRIX Z390-H GAMING specs drivers
Intel® Z390 Chipset Intel® 300 Series Chipsets
Microsoft Windows 10 Pro 10.0.18363 Build 18363
Did you install the standalone Intel® RST Driver before installing the Intel® Optane™ Memory and Storage Management application from the Microsoft* Store?
Wanner G.
Wanner_G_Intel
Hello U.Ped,
Were you able to review the recommendations provided?
Wanner G.
Wanner_G_Intel
Hello U.Ped,
We have not heard back from, so we will close this thread. If you need further assistance, please start a new thread, we will be glad to help you.
Wanner G.
U_Ped
Hi. Sorry for late answer.
Yes, I installed the RST Driver before Intel® Optane™ Memory and Storage Management App
Wanner_G_Intel
Hello U.Ped,
Please allow us to look into this issue.
Wanner G.
U_Ped
Yes. Please let me know if you need more information
Wanner_G_Intel
Hello U.Ped,
We are still looking into this issue.
Please make sure your OS is up to date. After verifying this, please run the Intel® System Support Utility (Intel® SSU) and send us the report.
Also, please provide us with an Intel® Rapid and Storage Technology System Report.
Note: You might need to install the Intel® RST User Interface.
  4. Click Save
Wanner G.
U_Ped
Hi. I had sent you a message with requested reports
Wanner_G_Intel
Hello U.Ped,
Thank you for the update.
Wanner G.
Wanner_G_Intel
Hello U.Ped,
Wanner G.
