Rapid Storage Technology
Intel® RST, RAID
1977 Discussions
Intel(R) ESB2 SATA RAID Controller and 3TB HDD
DT4
Hello!
Does Intel(R) ESB2 SATA RAID Controller fully support 3TB hard drives?
We have:
1) Intel Matrix Storage RAID - Intel(R) ESB2 SATA RAID ControllerNumber of Serial ATA ports: 6RAID Option ROM Version: 5.6.2.1002Driver Version: 8.9.0.1023
2) Intel Rapid Storage Technology
Intel RAID controller: Intel(R) ESB2 SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 5.6.4.1002
Driver version: 10.1.0.1008
Can we attach 3TB HDD to these controllers? Can we use whole capacity of such HDD ?
Daniel_O_Intel
It can also depend on the motherboard. Which board are you using this on?
DT4
Hello
Motherboard manufacturer: SupermicroMotherboard Model: X7DBR-3 BIOS Version/Date: Phoenix Technologies LTD 6.00, 05/29/2007
I am experiencing same issue with HP XW8600 thath has ESB2 Sata Raid Controller.
OS Win7 64b Ultimate
Seagate 3TB STBD3000100
I read the following and tried to install latest drivers from intel download f6flpy-x64 version 12....
Seagate says that it requires version version 10 plus Driver although it won't allow me to update from 9.6.0.1014 3/3/2010 to the latest version which is 12.... Please help so i know if I should return the seagate 3 gigs and give up on this MB....
Thanks for your help.
Also found this link regarding same issue
http://forums.seagate.com/t5/Barracuda-XT-Barracuda-Barracuda/Hooking-up-3TB-seagate-barracuda-drive/td-p/102204 Hooking up 3TB seagate barracuda drive - Seagate Community Forums <!-- WORP base href is only for viewing file on local system. Remove before uploading code to app --> Welcome to the Seagate Forums! - Seagate Community Forums
is anyone still following this topic? Help Intel please...
All,
You should check with your motherboard manufacturer for the most accurate compatibility information.
John
