Rapid Storage Technology
Intel® RST, RAID
2238 Discussions
Intel RAPID storage technology is not running
dears the app intel rapid is not running even the app installed successfully please how to fix the application to run again ??? please need help
Jose_H_Intel1
I believe the cause is probably related to the operating system or something else, considering that the issue is happening with several different versions of Intel® Rapid Storage Technology.
I would try a system restore or system refresh.
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc How to refresh, reset, or restore your PC - Windows Help
thanx my friend for your replay but these steps didn't help still not run and i can find the app. i thing there is wrong with installation !!!
my laptop is dell alienware 14 (2013 series)
Jose_H_Intel1
Did you uninstall and reinstall the application again?
Do you know what is the chipset model included with your system?
http://www.intel.com/support/chipsets/sb/CS-009266.htm Chipset Software — Utility to Identify Your Intel® Chipset
the application is not listed on the programs featured anymore so i can't uninstall it in a regular way and also if i install it again it will set up normally and give me installed successfully but in fact the application disappeared and not running even gave me successfully installed every time
i have windows 8.1 and Intel ship-set
System SummaryProductAlienware 14Service TagExpress Service Code129-426-451-93Operating SystemOperating SystemNameMicrosoft Windows 8.1 (64-bit)Build Number9600DirectX Version11Windows Directoryc:\windowsSystem Directoryc:\windows\system32Maximum OS Memory192.00 GBSystem NameASSOMAUser Namekassim banawerWindows UpdateAutomatic UpdatesAutomatic download and installLast checked<...
Jose_H_Intel1
hello Mr joe
yes that's right the problem was from windows itself, i already reset my windows and the problem is solved, i would like to thank you for your help Mr joe, with my best regards wish you good day goodbye
Jose_H_Intel1
I am glad I was able to help.
