Rapid Storage Technology
Intel® RST, RAID
2239 Discussions
Intel RST (SRT) - can't set SSD as cache
GGode1
Hello! I am having issues with setting up my SSD as a cache for my HDD.
Up until recently I was using a setup of 60GB SSD + 2TB HDD. The SSD held my OS. Now I bought a new SSD which is 250GB for the OS and planned on using the 60GB one as a cache for my HDD, however the issue I'm having is that I can't seem to "accelerate" the HDD.
SSD 60GB - https://www.cnet.com/products/ocz-vertex-plus/#p=ocz-vertex-plus-60gb/
SSD 250 GB - https://www.cnet.com/products/samsung-860-evo-mz-76e250b-solid-state-drive-250-gb-sata-6gb-s/
HDD 2 TB - https://www.cnet.com/products/wd-green-wd20earx-hard-drive-2-tb-sata-600-series/
The motherboard I have is
P8H67-M LE - https://www.asus.com/Motherboards/P8H67M_LE/specifications/ with the following chipset
Intel H67 Express Chipset - https://ark.intel.com/content/www/us/en/ark/products/52807/intel-h67-express-chipset.html That chipset is supported by RST, since its series 6? (I'm getting lost in this part).
Anyway. On my motherboard I have 4 SATA II (light blue) and 2 SATA III (gray) sockets.
Currently I have the 250 GB SDD and the HDD on SATA 3s and the 60GB on SATA 2 (according to their specs). As usual I made a fresh install of Windows 10 and set the bios in RAID (250GB SSD has OS, 60GB SSD is empty and the 2TB HDD has some data on it) - the RST driver/software is the latest from the site: https://downloadcenter.intel.com/download/29094/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005 (Setup RST)
Any advice would be appreciated...
Edit:
I figured out that SRT is not supported by RST versions > 16.0, so I tried with versions below that one - still no success.
2nd Edit:
Fixed the link to my motherboard.
Wanner_G_Intel
Hello GGode1,
Thank you for submitting your question on this Intel® Community.
To better assist you, please let us know the Intel® Processor model number installed in your computer.
Wanner G.
A Contingent Worker at Intel
GGode1
Hello, WannerG!
The processor model is Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz, 3301 MHz, 4 Core(s), 4 Logical Processor(s)
n_scott_pearson
How far back did you go? You likely have to go farther. In my archive for 6 Series boards, I have version 11.7.0.1013.
GGode1
I've tried the following versions:
15.9.8.1050 - https://downloadcenter.intel.com/download/28997/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005 (should be supporting my chipset, but acceleration still doesn't show up)
14.8.16.1063 - https://downloadcenter.intel.com/download/26759/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005 (doesn't seem to support 6th generation, but was worth a try)
11.5.0.1207 - https://www.asus.com/Motherboards/P8H67M/HelpDesk_Download/ (this one is for P8H67-M motherboard, whereas mine is P8H67-M LE, but the chipset seems to be identical - avaliable for W8 64bit under SATA)
12.8.0.1016 - https://www.asus.com/Motherboards/P8H67M/HelpDesk_Download/ (this one is for P8H67-M motherboard, whereas mine is P8H67-M LE, but the chipset seems to be identical - avaliable for W8.1 64bit under SATA)
10.1.0.1008 - https://www.asus.com/Motherboards/P8H67M_LE/HelpDesk_Download/ (this one is for my specific motherboard P8H67-M LE, for Windows 7 64bit, as for the later versions don't have SATA driver/software)
11.2.0.1006 - https://www.win-raid.com/t25f23-Which-are-the-quot-best-quot-Intel-AHCI-RAID-drivers.html?fbclid=IwAR2EHQJJCWTIPfxT_2swsZW1eC8PDlF-7vA3zDvzO8LHYdTDqGU9ByUta-U (listed as one of the best drivers for 6th generation)
Neither of the above worked for me, some even lacked the "Performance" tab altogether. I also tried installing a specific RST software and switching around drivers - but that resulted in errors while opening RST most of the time.
Honestly, I am running out of ideas.
Could it be also possible that im unable to accelerate the HDD with older software/driver since it doesn't contain the OS?
Actually that doesn't make sense, since I'm trying with 15.9.8 and 14.8.16 as well - they're not that old...
n_scott_pearson
I am unsure. If you would like to try it, I can provide you with a copy of the 11.7.0.1013 version that I have in my archive.
GGode1
Hey! I decided to change my setup seeing as this problem seems to be "unsolvable" with my current specs.
Thank you for the time you spent!
