Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
Intel RST driver 12.6.0.1033 not saving cache mode
twalk5
I've tested this with version 12.5.0.1066 and the latest 12.6.0.1033 for windows 8, the system has the express chipset
when I restart my system, the RAID array performance settings are reverting back to a default mode with:
- write-cache buffer flushing: enabled
- cache mode: none
when I have set the system for:
- write-cache buffer flushing: disabled
- cache mode: write back
after rebooting the system defaults (as noted above), I have to open the RST application, disabled flushing and re-enabled the cache mode... otherwise performance is terrible...
is there a workaround to this, or something in the registry that needs to be cleared or modified?
thanks!
Fred_D_Intel
twalk5
unfortunately, I do not think this will be possible on it..
baseboard: GA8-IBLV
BIOS: AMI, 4.6.4
system uses UEFI... so if you know where Intel puts that bios update for that board, that could be solution.
twalk5
hi, is there any updates to this or any ideas on how to correct or set these properties permanently in registry?
anyone else seen this behavior?
MCocq
Hi, I'm seeing the same behavior with the same version of RST after upgrading my motherboard and CPU. I'm Using an ASRock Z87 Extreme6 with a raid5 array.
Any help appreciated!
P.S. The password requirements for registering here are ridiculous.
DArce
Valued Contributor III
Could you please clarify if you refer to the disk/volume-write back cache or to the Intel® Smart Response technology acceleration cache?
MCocq
Well I'm not 100% clear on the terminology, but there are two caches, both configured through the Intel RST app, which lose their settings each reboot.
One is under "manage array" and is called "disk data cache". It has two settings, enabled and disabled. I set it to enabled but it resets to disabled each time I reboot.
The other is under "manage volume -> advanced" and is labelled "cache mode" - you can select write-back, write-through, read only or off. It is returning to "off" after I set it as "write back".
Hope that clarifies
twalk5
I can confirm that this is for volume write-back cache mode... system is defaulting to "none" after being enabled and the system rebooted. not optimal performance.
DArce
That type of issue has been reported before and it has been addressed correcting the configuration settings on the operating system, this is not caused by Intel(R) Rapid Storage Technology.
You may refer to this thread as a reference for the troubleshooting you can follow:
/thread/12381 http://communities.intel.com/thread/12381
Some others have reported that if you need to check the "Turn off Windows write-cache buffer flushing on the device" option on Policies tab in the RAID volume properties (Disk Management> Computer Management > Device Manager > Disk Drives.
Also check on policies to see that "Enable write caching on the disk" is checked and that "Enable advanced performance" is also checked.
Keep in mind that when using that type of cache, an UPS should be used and that the operating system may disable this cache feature, if an UPS is not present, which switches back to write-through
MCocq
Hi Diego, thanks for the reply.
I'm not sure that the thread you pointed me to has the solution though.
I can enable write-back caching without any problem (the turn off buffer flushing is ticked in the device manager) - it's just that the setting doesn't stick when I reboot.
Also I'm not sure where to find "Enable write caching on the disk" and "Enable advanced performance".
I do have a UPS too
DArce
The thing is that it is not Intel(R) Rapid Storage Technology what makes the settings persistent. The operating system's settings and policies or hard drives options are what will make the settings to remain through updates.
MCocq
Well that seems a bit screwy, seeing as the Intel(arrrrr!) software is the only place to configure this setting...
Also I never had this problem with my previous P35 chipset motherboard - it's only since a recent upgrade that has seen this problem...
It must be a marginal thing though, specific to particular setups, as I would have thought more people would have the same problem.
twalk5
ok, yes.. in device manager settings for the disk array you can set this property. I will try setting in this manner instead of via Intel toolset to see if after reboot the properties stick.
