Rapid Storage Technology
Intel® RST, RAID
Intel Rapid
EVOSONIC5
Moin, ich habe vor einigen Tagen das Rapid Storage Programm zum Test deinstalliert. Jetzt möchte ich es wieder installieren, weiß leider nicht welche Version ich runterladen muss???
n_scott_pearson
We can't help you if you don't provide sufficient information regarding your system. What version of Intel RST is present in your BIOS? What O/S are you running (is it, for example, Windows 10 64-bit version 21H1)?
If you want to attempt this blindly, the latest release can be downloaded from here: https://www.intel.com/content/www/us/en/download/15667/intel-rapid-storage-technology-intel-rst-user-interface-and-driver.html?wapkw=intel%20rapid%20storage%20technology%20driver.
EVOSONIC5
Hallo, danke für Ihre Antwort.
Ich hab mal die Dxdiag angehängt.
VG
lanaroseee
I can't understand your question properly please explain your problem in details. Thanks
n_scott_pearson
And what does a DXDIAG report have to do with the issue?
Please download and run the Intel System Support Utility for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
EVOSONIC5
Ich dachte, das Ihnen die Daten bezüglich der Treiber/Softwareversion helfen könnten.
VG
n_scott_pearson
Here's a link to the download page for the version of RST supporting your chipset: https://www.intel.com/content/www/us/en/download/15667/intel-rapid-storage-technology-intel-rst-user-interface-and-driver.html.
Hope this helps,
EVOSONIC5
Hi, thanks for the help. Worked great. Even if it was a long time ago. Thank you
