Rapid Storage Technology
Intel® RST, RAID
Avisos
2190 Discusiones
Intel VMD prevents Windows from booting — how to enable it on existing installation?
Cerphentos
Principiante
820 Vistas
Hello!
I’m trying to use a ssd as cache for my hdd. i have an image/video hoarding problem, and i like to see my files from time to time so i often open my hdd to see my files, according to copilot, Intel RST could do the work, but it could help me more.
 I’m trying to enable Intel VMD in BIOS. However, my current Windows 11 installation was created with VMD disabled (AHCI mode). When I enable VMD in BIOS, Windows fails to boot — it doesn’t detect the drives.
Here’s what happened:
  • I enabled VMD in BIOS and rebooted.
  • Windows failed to boot properly — I got a recovery error screen.
  • I opened the command prompt from the recovery tools, but diskpart showed no drives (list disk was empty).
  • I reverted BIOS settings to disable VMD, and Windows booted normally.
  • I tried installing Intel VMD drivers from my motherboard’s support page, but I’m unsure if I used the correct version or installed them properly.
  • After reinstalling the drivers and re-enabling VMD, the issue persisted — Windows still couldn’t detect any drives.
My setup:
  • System SSD (NVMe): XPG GAMMIX S70 BLADE — boot drive
  • Secondary SSD: KINGSTON SNVS500G — intended for caching
  • HDD: ST8000DM004-2U9188 — main storage
  • MOBO: PRO Z690-A WIFI (MS-7D25)
  • CPU: i7-12700KF
  • OS: Windows 11 Pro x64 (24h2 – 26100.6584)
Goal:
I want to keep my current Windows installation and enable VMD without reinstalling the OS. Is there a supported method to inject the VMD driver into my system and make it bootable under VMD? Which exact driver version should I use, and how should it be installed to ensure Windows can load it during boot?
0 kudos
3 Respuestas
Mike_Intel
Moderador
707 Vistas
Hello Cerphentos,
  1. Are you also trying to create RAID volume?
  2. Do you have a full data backup of your Windows 11 system?
  3. Have you also tried contacting the motherboard manufacturer regarding this inquiry? If yes, can you share their feedback?
Michael L.
Cerphentos
Principiante
687 Vistas
    1. I'm not entirely sure if what I want qualifies as a RAID setup. My goal is for my HDD and one SSD to appear as a single volume in Windows Explorer, with the SSD acting as a cache for the HDD. I’m unsure whether this configuration would be considered a RAID array.
2. Not exactly — I don’t have a full backup of my Windows 11 system, but I don’t keep anything critical on the C: drive. If reinstalling Windows becomes necessary, I’m prepared for it. My personal files are stored on the HDD and backed up to a NAS.3. I haven’t contacted the motherboard manufacturer yet. I wasn’t sure whether to start with Microsoft, MSI, or Intel, so I decided to begin here.
jbruceyu
Nuevo Colaborador I
436 Vistas
Hey mate, Just to be straight with you switching from AHCI to Intel® VMD after Windows is already installed isn’t supported. That’s why you’re hitting the “Inaccessible Boot Device” error  Windows simply doesn’t load the VMD driver early enough at boot. Intel® RST 18.0+ supports VMD on 11th Gen and newer (your Z690 + 12th Gen is fine). VMD needs to be enabled before installing Windows switching after install almost always breaks boot. RST/VMD drivers are Windows-only (no Linux). Optane caching only works if the platform/storage devices are fully validated. there’s no safe way to inject the driver into your existing setup. The only supported route is a fresh Windows install with VMD enabled from the start. If you want to see if there’s a workaround, best bet is to check directly with MSI.
Here’s the official guide from intel Intel VMD
hope it helps....
Responder
