Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
Keep getting a drive fail on the same port
PLaFl
I have 4 drives in a Windows 2016 server. There are two raid arrays set up as RAID1. I keep having the same drive slot reporting as failed. I've put 2 new drives in there and the RAID rebuilds fine, runs for a couple weeks, then says failed. I'm not sure if I have an MB problem or a software problem.
I took the two old drives that had originally been taken out of the RAID as failed and found that the data seems fine. I used Crystal Disk Info to confirm that the hardware itself is fine.
Any suggestions on how to troubleshoot this? The error notification I receive is as follows:
SATA disk on Controller 0, Port 2: Failed.
Volume Data: Failed.
System Report
System Information
OS name: Microsoft Windows Server 2016 Standard
OS version: 10.0.14393
System name: WIN16A
System manufacturer: Micro-Star International Co., Ltd.
System model: MS-7B48
Processor: GenuineIntel Intel64 Family 6 Model 158 Stepping 10 3.6 GHz
BIOS: American Megatrends Inc., 2.40
PCH: 0xA2C9
Intel® Rapid Storage Technology enterprise Information
Kit installed: 16.0.2.1086
User interface version: 16.0.2.1086
Language: English (United States)
RAID option ROM version: 16.0.1.3397
Driver version: 16.0.2.1086
ISDI version: 16.0.2.1086
Storage System Information
RAID Configuration
Array Name: SATA_Array_0000
Available space: 4 MB
Number of volumes: 1
Volume member: OSVOL
Number of array disks: 2
Array disk: WD-WMATV3656846
Array disk: WD-WMATV6680701
Disk data cache: Enabled
Array Name: SATA_Array_0001
Volume member: Data
Array disk: 9QJ4BAKF
Array disk: WD-WMATV6487410
Volume name: OSVOL
Status: Normal
Type: RAID 1
System volume: Yes
Data stripe size: 64 KB
Write-back cache: Off
Initialized: Yes
Parity errors: 9
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Volume name: Data
Status: Failed
Type: RAID 1
System volume: No
Write-back cache: Read only
Initialized: Yes
Parity errors: 0
Blocks with media errors: 1
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller \\Scsi0
Type: SATA
Mode: RAID
Number of SATA ports: 6
Number of volumes: 2
Volume: OSVOL
Volume: Data
Number of spares: 0
Number of available disks: 0
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 0
Direct attached disk: WD-WMATV3656846
Direct attached disk: 9QJ4BAKF
Direct attached disk: WD-WMATV6487410
Direct attached disk: WD-WMATV6680701
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Array disk
System disk: No
Command queuing: NCQ
Transfer rate: 3 Gb/s
Model: WDC WD1002FBYS-02A6B0
Serial number: WD-WMATV3656846
SCSI device ID: 0
Firmware: 03.00C06
Disk on Controller 0, Port 1
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Model: ST31000340NS
Serial number: 9QJ4BAKF
SCSI device ID: 0
Firmware: MA08
Disk on Controller 0, Port 2
Status: Failed
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: WD-WMATV6487410
SCSI device ID: 0
Firmware: 03.00C06
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
Usage: Array disk
System disk: No
Serial number: WD-WMATV6680701
SCSI device ID: 0
Firmware: 03.00C06
Empty port
Port: 4
Port location: Internal
Empty port
Port: 5
David_V_Intel
Hello PLaFl, Thank you for posting on the Intel ® communities. I would like to know if you tried other drives in the port where it shows failed, this it to see if, no matter the drive, the Intel ® Rapid Storage Technology shows as failed. Also, please provide me with an System Support Utility report, this report can be generated from our tool, you can refer to the link below so you can download it:  https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Make sure to attach the created report to this thread. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
Hello PLaFl, I am following up with your case and see that we have not heard back from you. Did you try other drives? Also, please provide me with the information requested. If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
PLaFl
Honestly I decided to just move on and break the RAID array. I was frusted by your question about whether I had tried other drives in that port. I explained in my original that I have put two new drives in there and within a few days to a week after rebuild, it reports that drive as failed again. I needed to get the server going so I moved on.
From now on I will use only hardware RAID as the Intel software RAID does not seem reliable.
Thank you anyways,
Paul
