Rapid Storage Technology
Intel® RST, RAID
2252 Discussions
Matrix Manager on Windows XP hardware requirements
btaylorh
Good afternoon. I am currently replacing a PC that runs one of our machines. The old system had a RAID 1 setup running Intel Matrix Manager. It appears as thought the chipsets on the motherboard would support Matrix Manager. The Matrix Storage Console software is installed on the computer. However, I do not believe there are any drivers or anything installed as it does not show up in the boot up sequence and I get "A plug-in did not provide a page for the selected device" and "A plug-in failed to load" errors when I open the management software in Windows. I also did not see anything in the BIOS.  Is it possible to enable Matrix Manager in the absence of all this?
JeanetteC_Intel
Hello btaylorh,
I'll check on this query and I will post an update once it's available.
JeanetteC.
btaylorh
Thank you for your reply. Here is some additional information on the system if it helps:
IDE ATA/ATAPI Controllers
Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Intel(R) 82801 GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Processor
Intel(R) Celeron(R) M CPU
440 @ 1.86GHz
Thanks!
JeanetteC_Intel
Hello btaylorh,
Good day.
You may check and follow the steps regarding Matrix Manager listed in the following links below:
Please also ensure that RAID is enabled in the BIOS. Sometimes, the RAID option might be under a different menu or sub-menu, so it’s worth thoroughly checking the BIOS settings. Therefore, I highly recommend contacting your system manufacturer support or OEM.
I hope to hear from you soon.
JeanetteC.
ACarmona_Intel
Hello btaylorh,
We would like to know if you have any questions regarding the recommendation that we have provided.
If so, kindly inform us, as we would be glad to assist you.
Carmona A.
ACarmona_Intel
Hello btaylorh,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
