Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
May i know intel c600+/c220+ series raid controller card can support hdd size 4TB? what is the maximum size can be use?Thank You
MZikr
Leonardo_C_Intel
Hello MZikr Thank you for posting in the Intel Community. • What is brand and model of your system? • Are you using an embedded RAID controller or a RAID controller card? if you are are using a RAID controller card what is the model? Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
MZikr
The server name is Serverware.its customize server..
Below i provide the link
https://www.serverware.com.my/
MZikr
posted a file.
Leonardo_C_Intel
Hello MZikr Thank you for the information. These customize servers set ups and the information related to the system design has to be confirmed with the Original Equipment Manufacturer (OEM) in this case I recommend contacting the ServerWare (https://www.serverware.com.my/#signup). Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
