Rapid Storage Technology
Intel® RST, RAID
2252 Discussions
Network performance problem with Intel RST driver 16.8.0.1000
MPron
( this is a subject that was first part of the NIC section https://forums.intel.com/s/question/0D50P00004F0w4BSAR/udp-dropped-packet-on-optiplex-7060-intel-xeon-e3-12001500- )
We encountered a UDP performance problem (packet losses in direct Ethernet link) with one of our application when using some computers ( Dell Optiplex 7060 and Lenovo P330 to name them, with Windows 10 1803 and 1809).
We found a direct link with the Intel(R) 300 Series Chipset Family SATA AHCI Controller in version 16.8.0.1000. By rolling back the driver to the Microsoft AHCI default driver, the problem disappeared instantly. The problem reappeared while reactivating the Intel version. The Intel RST driver was installed through the Windows driver update mechanism.
We have some questions around this topic :
  1. Is there some known issues caused by this Microsoft default driver ?
  2. Is there a new driver coming that may correct this issue ?
Leonardo_C_Intel
Hello MPron Thank you for posting in the Intel Community. Is there some known issues caused by this Microsoft default driver? In order to confirm if there is an issue caused by the Microsoft default driver we recommend contacting Microsoft support. Is there a new driver coming that may correct this issue? Intel does not comment about non release products due to of internal policies. I would recommend contacting the system manufactures for them to investigate the behavior with the same hardware configuration. Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
NeilF
*ignore - wrong thread*
SWill30
Due to the low network performance I cannot install itunes on windows 7 which is creating huge problem. Please help me to fix the problem so that I can work with the iTunes again.
Leonardo_C_Intel
Hello SWill30
I recommend creating a new thread to isolate your case and system configuration, please make sure you add the information of the system model and specs, detail information of the problem that you are having, plus all the information that you have added to this thread, so we can get more information about the problem.
Thank you; hope to hear from you soon.
Leonardo C.
