Rapid Storage Technology
Intel® RST, RAID
2056 Discussions
Problem with RSTe driver 3.1.0.1085 or above
Hi community, I upgraded the RSTe driver for my RAID 5 array on an X79 board to version 3.2.0.1135 (latest).
When I go to boot into safe mode through advanced boot options or msconfig I get a blue screen while loading the "classpnp.sys" file on the safe mode boot screen.
The blue screen has no error code just the standard "an error has occurred" text then stating "IAStoreA.sys" and again with no status or error code.
Also I am unable to get a memory dump because windows cannot access the array to dump the data onto; but when I downgrade to version 3.0.0.3020 the problem disappears. so this is more of a bug report then a support request, I was also wondering if anyone else has the same problem with X79 based systems.
My Specs:
12GB of 1600MHZ memory
Intel i7 3820
Gigabyte GA-X79-UD3
Corsair 850W power supply
2x Samsung F1 7200RPM 1TB drives
1x WD Caviar green 5400RPM 1TB drive
All drives are members of the RAID 5 array
Message was edited by: Peter De Sousa
Since the X79 chipset is installed on a third party motherboard in this case, our recommendation is contacting our chipset support via chat at the following website:
http://www.intel.com/support/feedback.htm?group=chipset# chipset Contact Intel Customer Support
You can also contact the vendor for further assistance on reporting this bug.
