Rapid Storage Technology
Intel® RST, RAID
Problem with Raid5
MSopa
Hello, i have a problem with my raid 5.
Problem started when i tried to put my computer to sleep. It turned off, then on again and then in bios window it shows status "Rebuild" but all drives are green. https://imgur.com/a/fgMqK https://imgur.com/a/fgMqK
But when i look in intel's Rapid storage app it shows problem with one of my drives.https://imgur.com/a/LRRhn https://imgur.com/a/LRRhn
What i should do at this point ?
Ive already tried WD disc utility tool and tested. Raid passed the test
Hello salemas5,
Thank you for joining the Rapid Storage Technology. I am sorry to hear you are having issues with this matter.
Could you please provide your https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html System Reports for Intel® Rapid Storage Technology report?
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Amy C.
MSopa
Sure thing. Here's my system report.
Thank you for the file /thread/121192?prevContainerType=14&prevContainerID=2847 salemas5.
Please try the following suggestions:
  • Try to change the disk from the current SATA port to the where you currently have connected the optical drive (HL-DT-ST BD-RE BH16NS40).
  • You can also try with a different SATA cable or use the same cable from the optical drive.
  • Another suggestion is to set the disk that is causing this issue as non-RAID, only that disk. I believe the serial number is WD-WMC1F0655116, please verify that. Then go back to the Intel® RST software and try to add the disk to the RAID 5.
  • You can also update your Intel® RST version to version 14.8: https://downloadcenter.intel.com/download/26759/Intel-Rapid-Storage-Technology-Intel-RST-?product=55005
Let me know how it goes.
Amy C.
MSopa
Okei, strange things happening. Firstly i decided to try software level changes before messing with cables. So ive updated RST as you sugested. And now looks like my computer recognises that HDD. It started rebuilding process. So i notify how that goes. Fingers crossed.
/thread/121192?prevContainerType=14&prevContainerID=2847 salemas5, good to hear! Please let me know how it goes.
Amy C.
MSopa
Disc rebuild is complete and system is back to normal. Thank you for your support, intel_corp :3
