Rapid Storage Technology
Intel® RST, RAID
2197 Discussions
RAID 5 No rebuild option after replacing drive
rmicona
I have a RAID 5 setup on a thinkserver ST250.
One of the drives failed, it became an unknown device. Status: Controller Unknown, Port Unknown.
I installed a replacement drive into its slot and scanned, the drive shows up but the only option I have is to mark as spare.
I have no Rebuild to another disk option and auto rebuild doesn't seem to be taking place.
I also noticed the old failed drive is still showing even tho its not connected anymore.
Any help would be great.
I attached some photos of what I am seeing.
RandyT_Intel
Hello rmicona,
To assist you effectively and resolve your issue, I need some additional information. Kindly provide answers to the following questions:
  • What is the model/version of your RAID controller, and is its firmware up to date?
  • Which RAID management utility are you using (e.g., MegaRAID Storage Manager, Lenovo XClarity Administrator)? Have you tried accessing the utility to manually remove the old drive entry?
  • Is the replacement drive identical in specifications (e.g., capacity, speed, model) to the failed drive?
  • Have you tried reinitializing the new drive through the RAID management utility? If so, what was the outcome?
  • Have you checked the BIOS/UEFI settings to ensure the RAID controller is correctly configured and that there are no conflicts?
  • Have you attempted to rebuild the array manually before, and if so, what steps did you take and what were the results?
I have also attached an article that might help resolve this issue.
Degraded RAID Volume Won't Rebuild After Failed Hard Drive Is Replaced (intel.com)
How to Rebuild a degraded RAID (intel.com)
Randy T.
RandyT_Intel
Hello rmicona,
Randy T
RandyT_Intel
Hello rmicona,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Randy T
