Rapid Storage Technology
Intel® RST, RAID
2208 Discussions
RAID0 Array Only Half Expected Size
TMann1
Referring to
The solution is utterly straightforward:
If you have the same problem as SrqDan, then:
On disk management, right-click on your C: drive under Disk 0
Select 'extend volume' & give it the maximum, then click extend; that's it!
Hello TheMan1000000,
Thank you for posting on the Intel ® communities.
I appreciate you taking the time to provide us with this feedback. Let us hope other community members refer to this for further assistance with this and try your method.
Again, thank you for your help and feedback provided.
David V
Under Contract to Intel Corporation
