Rapid Storage Technology
Intel® RST, RAID
2208 Discussions
RST VMD driver - unable to read NVMe SMART data
TomSawyer8006
I'm using a MB with Z690 (with latest bios version).
I've installed 2 x Samsung 980 Pro NVMe SSD.
The SSDs are in a RAID 1 setup (from bios).
I've installed Windows 11 - it went well.
The storage controller is Intel RST VMD Management Controller 09AB.
I've tried driver versions: 18.6.1.1016,  19.0.0.1067 and 19.0.19.2.0.1003 (currently installed).
I can view the RAID Array and the NVMe SSDs (raid members) in the Intel Optane Memory and Storage Management.
The problem is I can't view the SSD's SMART data.
I've tried to view the SMART data with other software i've used before (exp: GSmartControl, Smartmontools, ...) but none of them were able to view the NVMe SSDs SMART data.
Does the RST VMD driver support NVMe Pass-Through in a raid configuration? If not, will this feature be added at some point?
Is there anything I can do in order to view the SMART data of the SSD's (raid members) ?
Thank You!
