Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
RST disaables auto-rebuild by default. Is there any reason it should not be enabled?
BLich
A basic reason for RAID 1 is to image a new drive in the event of failure of one of the RAID 1 drives. Why is aut-rebuild disabled as default and is there any downside to enabling it?
Allan_J_Intel1
What is the Intel® Rapid Storage version you are currently running on the computer?
Also, I would like to have your computer model number.
Allan.
BLich
Computer: Hewlett Packard HP 580T
RST: 14.0.0.1143
Appreciate your assistance.
Ben
Allan_J_Intel1
Thanks for the information.
Based on the product specifications, you are currently on Intel(R) X58 express chipset or ICH10R, please test the latest Intel® Rapid Storage supported by the X58 chipset version 11.6
https://downloadcenter.intel.com/downloads/eula/22036/IRST-Intel-Rapid-Storage-Technology-Intel-RST-?httpDown=https://downloadmirror.intel.com/22036/eng/iata_enu.exe IRST: Intel® Rapid Storage Technology (Intel® RST)
Allan.
BLich
12.0 works but auto-rebuild still is defaulted to disable. Should I enable it and why should it default to disable, just the opposite of iRST's purpose??
Ben
Allan_J_Intel1
It should not disable the option, it might be some sort of compatibility issue. That is why I suggested 11.6
Allan.
BLich
I installed 11.6 and it still reads "Disabled" Should I simply enable? Any harm from doing that?
Ben
Allan_J_Intel1
This is a RAID 1, it mirrors the data you have on both drives. It should not delete or harm anything. I recommend backing up the information before you enable this option.
Allan.
BLich
RST reports "Disabled" and Preference will not allow it to chane to enabled. BIOS reports Raid 1 is active. Whats up?
Allan_J_Intel1
Please send pictures of the RAID BIOS and snapshot of the Intel® Rapid Storage.
Allan.
BLich
Thanks for your assistance. Attached are the 2 pieces of info you requested.
Ben
Allan_J_Intel1
Thanks to the pictures, I understand this issue. Since this is a software/hardware RAID controller, hot plug is disabled by default because the chipset model on your computer was designed that way. This would work for server or workstation chipset.
If you ever get disk failure, you would to perform rebuild manually through Intel® Rapid Storage software.
Allan.
BLich
"you would to perform rebuild manually through Intel® Rapid Storage software. Not sure how you can do that?
Ben
Allan_J_Intel1
Under Manage or Create tab you would be able to rebuild the existing array.
Allan.
