Dear all,
we have Raid 1 (HDU and SSD) at some our W10 PC.
With the new app from Intel it´s no more possible to configure to send a mail or
see a symbole at taskbar (That a normal user see, if the raid has a problem) .
How is it possible for me as admin to see, if a raid is degraded.
I don´t want connect to every PC, to check, that the raid is fine.
Thank you for your help, with best regards
Bernd
链接已复制
Hello
I miss that feature too!
It has just been removed from the new Intel Optane Memory and Storage Management GUI.
I used it to get the confirmation that the scheduled weekly verify task went through successfully.
can we have this back again?
cheers
Hello BerndV, cccleaner,
Thank you for posting on the Intel* Community.
To better assist you, please provide us with the specific app version you are using and a screenshot.
Provide the Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Maria R.
I send you the needed data.
Bernd
How is it possible, that a user without admin rights can check the raid status at windows?
Or is it possible, that a normal user get in Windows an info, if the raid is degraded?
Hello BerndV,
Unfortunately, we do not have information about the feature in future releases.
It may be possible to check this through Windows* notifications, in that case, we recommend you to contact Microsoft* to consult about this and if possible, how to enable it.
Maria R.
