Windows 11 - I want to get the status of an RST array using a scheduled task. I understand that this exe needs elevated privileges. I can't get the schedule task to successfully run rstcli64.exe
Any advice on how to do this?
This is my testing to date:
1) [FAIL] Created a schedule task to run rstcli64.exe and send the output to a file
- Task runs as an administrator
- Task set to Run With Highest Privileges
- Task runs
- Output not as expected
1) [FAIL] Created a schedule task to run a .CMD with the rstcli64 command in it.
- Task runs
3) [SUCCESS] Created a .CMD file with the rstcli64 command in it.
- Logged on as an administrator
- Using explorer, right-click cmd, run as administrator.
- UAC Prompt
- Output as expected
4) [SUCCESS] Create a shortcut to .CMD file with the rstcli64 command in it.
- Create shortcut and configure it to "Run As Administrator"
- Using explorer, double click shortcut.
- UAC Prompt
- Output as expected.
5) [SUCCESS] From an elevated command prompt
- Run cmd.
- No UAC prompt
Hello GingerNinja,
Thank you for posting in the community. I see that you've tried several workarounds to get the CLI tool to function properly. To provide you with an accurate answer, it's important to ensure that the Intel CLI tool and Intel RST are the same version. For example, if the latest version available for the Intel CLI tools is 13.2, then the Intel RST version should also be 13.2, provided it's compatible with your computer's chipset.
Could you please let me know the current version of your Intel RST? Additionally, can you confirm if you downloaded the rstcli64.exe from this link: Intel RST CLI Pro for Intel Optane Memory?
Dhanniel M.
Both the driver and the cli are the latest: 20.0.0.1038. Yes, I did obtain the cli from the link above.
Hello GingerNinja,
Thanks for the confirmation, can you tell me if you download the RST on this link Intel® Rapid Storage Technology Driver Installation Software with Intel® Optane™ Memory (10th and 11th Gen Platforms)?
Also, to better understand your entire system information, please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
Hello GingerNinja,
I hope this message finds you well. I wanted to check in to see if you've had the opportunity to review the information I shared earlier. Your feedback at your earliest convenience would be greatly appreciated, as it will help us proceed with resolving this matter.
John Sergio M.
Thanks for coming back to me. Due to the urgency I had to move away from this RAID solution.
Appreciate your help.
Hello GingerNinja,
I understand your situation. Given this, could you please let me know if we can proceed to close the inquiry?
Dhanniel M.
Hello GingerNinja,
Thank you for confirming the details. I will now close this inquiry. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored..
Dhanniel M.
