Rapid Storage Technology
Intel® RST, RAID
2246 Discussions
SetupOptaneMemory.exe Won't Install
DGrov1
Just built a new system with 32Gb Optane memory added to mother board. When running the SetupOptaneMemory.exe it shows the following error: UNSUPPORTED CHIPSET
Steps I've tried:
-Got the latest drives via Intel Driver & Support Assistant
-Intel SSD Toolbox is seeing the Optane card in the motherboard with the correct size. It say my motherboard can support Optane but the ENABLE button is grayed out.
-Followed all steps for Optane memory setup for the motherboard manufacturer and have confirmed all steps several times.
-100% new installation of Windows 10, nothing installed at all.
-Confirmed this chipset is supported.
Error from IntelOptaneMemory.log file:
2019:02:10 13:20:37:956:  Loading language 0409
2019:02:10 13:20:37:956:  Setup mode: Installation
2019:02:10 13:20:37:956:  === CpuChecker: Your CPUID is 0x906ec
2019:02:10 13:20:37:956:  === CpuChecker: Your CPU is not supported
2019:02:10 13:20:37:956:  === Device Enumerator: Starting enumerating all devices of type PCI
CPU Details:
Intel® Core™ i9-9900K CPU @ 3.60GHz
ManufacturerGenuineIntelDescriptionIntel64
Family 6 Model 158 Stepping 12Architecturex64
# of Cores8
# of Threads16
Current Clock Speed3600 MHz
Current Voltage9.
Level 2 Cache2048 Kb
Level 3 Cache16384 Kb
Processor IdBFEBFBFF000906ECAvailabilityRunning at full power
Thank you,
-DG
JosafathB_Intel
Hello DGrov1 Thank you for contacting Intel® Memory & Storage Support. As we understand, you need assistance with your Intel® Optane™ Memory. If we infer correctly we will appreciate if you can provide us with the following information: • The SSU logs. 1- Go to https://downloadcenter.intel.com/download/25293/ and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. • A screenshot of the “Disk Management” of windows showing all your HDDs and partitions. We will be looking forward to your reply including this information. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
DGrov1
Hi Josh,
Sorry for the delay. I've attached the requested items.
Appreciate the help!
-DG
DGrov1
..other requested image.
JosafathB_Intel
Hello DGrov1 Thank you for your reply. We reviewed the information you provided and based on the logs you shared with us we noticed the following: • Your system BIOS is set up in legacy mode. • Your OS is reporting to be OS Name: “Windows 10 Pro 64-bit (10.0, Build 17134)” This been said our advice is to back up your information, change your BIOS settings to UEFI mode(if possible) and reinstall your OS and to update your system to the latest version. If you have future questions, please don’t hesitate to contact us. We will be more than happy to help you in any way we can. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
DGrov1
Josh B! We are on to something here!
When I look at my BIOS is says it's set to UEFI (and has LEGACY grayed out).
But the option for UEFI is grayed out in the bios boot settings.
I'll ping the MSI board with this new info. You found the problem, now I gotta sort it on the MSI side. =)
Thanks, have a good weekend.
JosafathB_Intel
Hello DGrov1, Thank you for your reply. We are glad to hear that you found the information we shared with you helpful. If you need further assistance please do not hesitate to contact us. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello DGrov1, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello DGrov1, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
DGrov1
Hello Josh,
You can close this for now. I'm still troubleshooting and not making any progress.
Thank you,
-DG
JosafathB_Intel
Hello DGrov1, Thank you for your reply. As per your consent, this case is now close if you need further assistance please do not hesitate to contact us again, after you solve the issue you are experiencing with your OEM. Best regards, Josh B. Intel Customer Support Technician Under Contract to Intel Corporation
