Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Start up problems on 4 O.S. installed Need help
I have installed on one disk WD Caviar black Sata 3 1 TB on port 2: 3 windows 7 64 bit and 1 Windows 8 64 bit. When I boot on a different O.S. the start us process is slow and it takes one to two additional reboots to get the O.S. to accelerate at the start up. All other functions operate properly (video rendering with very satisfying processing time)
The processor is overclocked at 4500. In the bios raid Intel configuration the accelerated disk is marked as unsynced. I have tried to sync it without success.
Could you please let me know if there are any adjustments or corrections that I can make to get all O.S. to accelerate at the start up?
Thank you
System Information follows:
OS name: Microsoft Windows 7 Ultimate
OS version: 6.1.7601 Service Pack 1 7601
System name: GERASIMOS-PC
System manufacturer: System manufacturer
System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 42 Stepping 7 3,501 GHz
BIOS: American Megatrends Inc., 3506
Intel® Rapid Storage Technology
Kit installed: 11.1.0.1006
User interface version: 11.1.0.1006
Language: Greek (Greece)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 11.0.0.1339
Driver version: 11.1.0.1006
ISDI version: 11.1.0.1006
Hardware Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: Volume_0000
Number of disks: 1
Array disk: OCZ-B6J02WM1717LTV16
Status: Normal
Type: RAID 0
Usage: Cache volume
Data stripe size: 128 KB
Write-back cache: Disabled
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Parent array: Array_0000
Number of disks: 1
Disk on port 0
Port location: Internal
Status: Normal
Type: Solid-state drive
Usage: Cache device
Serial number: OCZ-B6J02WM1717LTV16
Model: OCZ-AGILITY3
Firmware: 2.15
Password protected: No
Native command queuing: Yes
SATA transfer rate: 6 Gb/s
Disk on port 1
Status: Normal
Type: Hard disk
Usage: Available
Serial number: WD-WCAZA8102909
Model: WDC WD20EARX-00PASB0
Firmware: 51.0AB51
System disk: No
Physical sector size: 4096 Bytes
Disk on port 2
Status: Normal
Type: Hard disk
Usage: Accelerated disk
Acceleration mode: Maximized
Serial number: WD-WCATR9401286
Model: WDC WD1002FAEX-00Z3A0
Firmware: 05.01D05
System disk: Yes
SATA transfer rate: 3 Gb/s
Disk on port 5
Status: Normal
Type: Hard disk
Usage: Available
Serial number: WD-WMATW0235725
Model: WDC WD7502ABYS-02A6B0
Firmware: 03.00C06
System disk: No
Disk on port 3
Status: Normal
Usage: Unknown
Serial number:
Model: Optiarc DVD RW AD-7280S
Firmware: 1.01
System disk: No
Disk data cache: Disabled
Native command queuing: No
SATA transfer rate: 1.5 Gb/s
Physical sector size: 0 Bytes
Logical sector size: 0 Bytes
Disk on port 4
Status: Normal
Usage: Unknown
Serial number:
Model: TSSTcorp CDDVDW SH-S223F
Firmware: SB00
System disk: No
Hello Gerasimos,
I see that you are having problems with the boot up time and the boot from the operating system disk.
In regards to the problems that you are experiencing I see that the power supply could be the problem. I recommend you to test with a higher wattage power supply.
I also recommend you to set a hard drive delay in BIOS to allow the hard drive to initialize.
PV
Dear Victor good evening
Thank you so much for your responce, although I do not have any actual problems everything is running ok just the start up time is longer when I switch to a different OS.
In ref to your suggestions, would you be so kind to send me some instructions how to do this as I am self taught and this is the first time that I am getting involved with this technology.
In the INTEL bios raid configuration that appears before the boot manager, the hard disc set up is the following:
1) Port 0: SSD 56 Gb for caching with the indication normal
2)Port 1: WD 1,8 Tb non raid HD
AND 3) Port 2: is the WD 1Tb non raid HD with the 4 OSs installed (3 win 7 64 bit and 1 Windows 8 64 bit concumers preview) This disc has the green star and indicates that is the accelerated disc. Pls dont ask me why I have installed 4 OSs, I can ony say that the other members of my family they prefer to have their own OS and not user's status.
Should I disable acceleration, connect the disc that I want to accelerate to port 1 the other (WD 1,8 Tb) to port 2 and enable acceleration again?
Regarding the Intel Rapid storage panel same here as well, pls check the following images:
Furthermore, I have the VIRTU control panel crashing on start up (not all the times, once every 3-4 starts)) and I have disabled it from the MSCONFIG. Could you please let me know if I do need it to start with the OS in order to have the VIRTU running?
Description:
Virtu controlpanel had Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: virtucontrolpanel.exe
Problem Signature 02: 1.2.112.20176
Problem Signature 03: 4f05d749
Problem Signature 04: GuiCommon
Problem Signature 05: 1.2.112.20176
Problem Signature 06: 4f05d739
Problem Signature 07: 27c
Problem Signature 08: 172
Problem Signature 09: System.NullReferenceException
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1032
Thank you once more for your assistance and support, much appreciated
Sincerely
Gerasimos
Dear Victor good evening,
Do you have any news for me?
I would really appreciate it
Thank you
Gerasimos
