Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
Updating RST + Drivers = Lockup on boot.
I just attempted to install the newest (3 December 2012 11.7.0.1013) RST package and the system freezes on boot.
I managed to squeak out of the lockup by running system repair/restore.
The system thinks it is booting off the 500GB and not the RAID array.
I switch out the 500gb from the boot lineup in BIOS and it refuses to boot at all.
How do I go about forcing the array to accept the MBR and boot like it should?hanged
Or should I do anything at all for it at all since it does run fine?
System Information
OS name: Microsoft Windows 7 Professional
OS version: 6.1.7601 Service Pack 1 7601
System name: TINKERTOY
System manufacturer: System manufacturer
System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 26 Stepping 4 2.668 GHz
BIOS: American Megatrends Inc., 2101
Intel® Rapid Storage Technology
Kit installed: 10.8.0.1003
User interface version: 10.8.0.1003
Language: English (United States)
Intel RAID controller: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Number of SATA ports: 6
RAID option ROM version: 8.0.0.1038
Driver version: 10.8.0.1003
ISDI version: 10.8.0.1003
Device Information
Available space: 0 GB
Disk data cache: Enabled
Number of volumes: 1
Volume member: Volume0
Number of disks: 3
Array disk: WD-WMAV2W654478
Array disk: WD-WMAV21945109
Array disk: WD-WMAV21920258
Status: Normal
Type: RAID 5
Data stripe size: 64 KB
Write-back cache: Enabled
System volume: Yes
Initialized: Yes
Verification errors found: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Parent array: Array_0000
Number of disks: 3
Disk on port 0
Port location: Internal
Status: Normal
Type: Hard disk
Usage: Available
Serial number: WD-WCAU45527480
Model: WDC WD10EADS-00L5B1
Firmware: 01.01A01
System disk: No
Password protected: No
Native command queuing: Yes
SATA transfer rate: 3 Gb/s
Disk on port 1
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: WD-WMAV2W654478
Model: WDC WD3200AAJS-56M0A0
Firmware: 01.03E01
System disk: No
Disk on port 2
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: WD-WMAV21945109
Model: WDC WD3200AAJS-65M0A0
Firmware: 01.03E01
System disk: No
Disk on port 4
Status: Normal
Type: Hard disk
Usage: Array disk
Serial number: WD-WMAV21920258
Firmware: 01.03E01
System disk: No
Disk on port 3
Status: Normal
Type: Hard disk
Usage: Unknown
Serial number: K9GA29J0512
Model: HL-DT-ST BD-RE BH10LS30
Firmware: 1.00
System disk: No
Disk data cache: Disabled
Native command queuing: No
SATA transfer rate: 1.5 Gb/s
Physical sector size: 0 Bytes
Logical sector size: 0 Bytes
Empty port
Port: 5
I had problems with these drivers as well.
I think that your 500 gig drive might have some bios loader that lets your system continue. While it you should see about resolving this issue, I would not recommend doing so until Intel comes out with drivers that work better (I think 11.7 drivers are junk, and I don't want to deal with them any more).
I have basically the same problem. After updating the driver Windows 7 freezes on boot.
Only chance is to use the Windows repair menu.
Just to let you know: In contrast to Nighthawke, I did not boot from the RAID device because I am using a seperate system hdd. However, the update still managed to freeze Windows boot.
Sadly, Intel seems not to be interested in this problem.
We need a solution!
I may have mistaken my assessment of my boot devices. I've checked where my MBR's reside, and oddly both drives report the partition in it on one application, the RAID array another.
Well, I have to assume the array has the current boot partition, I probably misconfigured the BIOS something fierce. This particular BIOS layout is designed for power users and can be tricky for the regular users.
Has anyone tried these drivers with a scratch installation?
RSant17
I have the same problem on Windows 8 x64 on an Alienware M18xR2 laptop.
I wasn't able to recover, refresh, or restore. I had to do a complete reinstall.
I really wish Intel would address what are obviously problematic drivers.
On another note, the Alienware drives from Dell are installed. I need the RST client software to migrate the OS that is on a single SSD to two RAID 0 SSDs. The OS was installed with RAID configured in the BIOS.
Is the RST client available separate from the drivers? Is there other software that works with the RST drivers?
