Rapid Storage Technology
Intel® RST, RAID
2253 Discussions
VMD driver for ESXI, Core processor
razzle_dazzle
I am using Intel core i7 13700 processor and supermicro x13sae-f motherboard.
I enabled VMD on the bios and created a RAID 1 as bootable volume. And I want install ESXI as the OS. But when I installing the ESXI, it can not recognise the VMD RAID volume, which is because the lack of driver of VMD for ESXI.
There is VMD driver for Windows that supports Core processors and VMD driver for ESXI that supports Xeon/W processors.
But I can not find VMD driver for ESXI that supports Core processors. Any advises? Thank you!
Steven_Intel
Hello razzle_dazzle,
I will research about your request, as soon as I have an update, I will let you know.
Steven G.
Steven_Intel
Intel Volume Management Device (VMD) works with the Xeon family of processors to enable additional control and management of NVMe devices. So, this is only supported on the Intel Xeon family, as the requirements for the drivers you found. There is no driver for Intel Core processors.
 There is some additional information on the following links:
Intel VMD-enabled NVMe Driver for VMware ESXi with RAID1 (https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/ssd-software/Intel_VMD_NVMe_VMWare_User_Guide.pdf).
Intel® Volume Management Device (Intel® VMD) ESXi Tools (https://www.intel.com/content/www/us/en/download/19356/intel-volume-management-device-intel-vmd-esxi-tools.html).
Steven G.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
razzle_dazzle
Hi Steven,
Thank you for your support!
VMD also works for core families too, as stated in i7 13700 information sheet
Kind regards,
Xia
DeividA_Intel
Thanks for your response. In this case, bear in mind that our support is oriented to Windows as well as our drivers, I recommend you to check with the ESXI developer to confirm if there are any drivers compatible with your system as well for additional support.
If you have any questions, please let me know.
Deivid A.
razzle_dazzle
Steven_Intel
Steven G.
Steven_Intel
We are glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it.
If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
