Rapid Storage Technology
Intel® RST, RAID
2190 Discussions
Why my Intel RST always fails to install?
kwnag
The computer prompts me that the disk is full or has no permissions.
And My Hard disk drive has 100G capacity...
Hello Kevin_wang
Thank you for joining the community
Could you provide us more information on the version of Intel® RST that you are using?
Share with us the Intel® System Support Utility for Windows* report on the following link
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-%20/ https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- \
Please add the report to the thread
Make sure that you have administrative rights on your systems
Leonardo C.
Hello Kevin_wang
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
JJaeg
FYI, I have seen lots of reports like that, where attempting to install RST drivers newer than, say, 11.x.x.x on a system with an older chipset (mine is X58 / ICH10R).
For me, an install of 14.8.16.1063 gave this same error (and also crashed my system - see ) as did an install of 13.6.0.1002 - the level I am currently running at.
In both cases, after the install, if I went into Device Manager, expand "Storage Controllers", find an entry with Intel and RAID (the wording seems to vary with release and/or chipset), double click that, click on the Driver Tab, then the Driver Details button, I found iaStorA.sys (for older release iaStor.sys) to be at the correct level.
I then went back and ran SetupRTS.exe with the -Nodrv option, and that completed successfully, and installed the user interface and tray tool.
