Rapid Storage Technology
Intel® RST, RAID
2209 Discusiones
Windows 8.1 on Lenovo Ideapad 3 14ITL05
rockzombie
Principiante
2.303 Vistas
Hello, everybody. Recently I tried to install windows 8.1 on my Lenovo ideapad 3 14ITL05 by using ventoy. While I was installing, I came across an error: `A driver your device needs is missing`. I tried to search for the correct RST drivers, but when I put whatever I found into my computer with a separate media, it either doesn't detect it at all, or it hides it because it is not supported on my device. I was hoping if I could find some driver files for windows 8.1 to be installed on my ideapad 3 14ITL05.
This is what I use just in case you might need the info:
Host: 81X7 IdeaPad 3 14ITL05
CPU: 11th Gen Intel i3-1115G4 (4) @ 4.100GHz
GPU: Intel Tiger Lake-LP GT2 [UHD Graphics G4]
Memory: 19.801 GB
Storage: 1 TB
Storage Type: NVME SSD
I am using an SD card as the installation media and a USB drive (2.0 I think) for driver media.
Thank you, please help me.
0 kudos
3 Respuestas
ACarmona_Intel
Empleados
2.213 Vistas
Hello Rockzombie,
Upon checking, here is the only validated operating system on your system:
  • Windows 11 Pro
  • Windows 11 Home
  • Windows 11 Home in S mode
  • Windows 11 Home, Single Language
  • Windows 11 Home Single Language in S mode
  • Windows 10 Pro 64
  • Windows 10 Home 64
  • Windows 10 Home 64 Single Language
  • Windows 10 Home Single Language in S mode
  • Windows 10 Home in S mode
It seems that Windows 8.1 is not included in the validated system on your system, and that might be the reason why you are having an error. In regards to this, we recommend that you contact Lenovo support to confirm it with them since the compatibility is between the board, BIOS, and OS.
Carmona A.
ACarmona_Intel
Empleados
2.169 Vistas
Hello Rockzombie,
We have not heard back from you, so we will close this enquiry now. For additional information, please submit a new question, as this thread will no longer be monitored.
By the way, please don't forget to contact Lenovo technical support for further assistance.
Thank you, and have a great day ahead.
Carmona A.
MerkoMutasam
Principiante
1.325 Vistas
Yeah I'll try windows 7 but I tried it it's always freeze on startup logo so you have to install the first version of Windows 10 1507 that supports my laptop and your laptop too I have the same laptop So I tried Windows 8.1 it shows my drivers but I tried it it says I I mean it says PC try to multiple times to load that didn't start up properly so I uninstall Windows 8.1 and I installed the first version of Windows 10 1507
Responder
