Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
abnormal status reported by rapid storage technology UEFI driver
CrusadOr
Hello!
Once I started my laptop and saw this:1.jpg
Then the BIOS automatically started and I saw this:
Restart did not help, but once I plugged the charger out - it started normally.
It also appers now when I install some drivers and restart the laptop to apply changes, or randomy after the restart. The solution is always same: turn off the power, plug out the cable, start the laptop.
What might be the problem and the solution?
SSU logs are provided
Kiriakos-GR
You should contact ASUS support instead.
If you did install Tweaked BIOS, and or Other Operating system than what this laptop originally sold with, then even ASUS it will shut their door to you.
