- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi!
I hope someone can help me.
In Task manager, startup, I see this:
Delayed launcher (2) and then underneath:
IAStoricon (a little indented underneath above delayed launcher)
Delayed launcher (again, a little indented)
startup impact: medium for all 3
I'm assuming it should not have a(2) and that it should be listed only once?
and I'm assuming it should be indicating/using a low startup impact.
How can I fix this?
thanks so much!
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello IntelHelpPlease,
Thank you for joining this community; it will be more than a pleasure to assist you.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
As well can you please provide with screenshots of your Task manager>startup and the RST version that you are running??
I hope to hear from you soon.
Diego S.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
how/where do I 'get' this .txt file? I don't think I have this utility thing? and what is RST and where do I get that? thanks : )
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I see! (the link was the download for the system support utility).
ok, so attached is the .txt file from that utility.
and the screenshot from task manager, startup.
I have windows 10, is that what you mean by which "RST version" I am running?
thanks in advance for any help you can provide!
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thank you for your response.
While taking a look to your account, we noticed that you currently have 2 open tickets regarding this inquiry.
This one, through public forums, and another ticket through our web/email team which is a little bit more customized since it is a private interaction.
Please let us know which of the 2 supports methods work better for you so we can go on.
Diego S.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I guess I'll keep the customized, web/email private interaction one. how do I do that? I didn't hear back from them, so I posted here. I'm so confused! and can you send them my attachments? thanks
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Denise. ,
We just forwarded your information to the e-mail team, we got your back.
They will contact you as soon as possible so we can continue with the assistance.
I hope this helps.
Diego S.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
The "iastoriconlaunch.exe" or Intel's "Delay Launcher" is a startup application that is part of the Intel Rapid Recovery Technology. It is recommended to keep this process enabled at startup.
Read more about this executable below...
https://www.scuttlenet.com/what-is-intel-delayed-launcher-and-should-i-disable-it/ https://www.scuttlenet.com/what-is-intel-delayed-launcher-and-should-i-disable-it/
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
