Rapid Storage Technology
Intel® RST, RAID
flexran build
chella
Hi Team,
During FlexRan build on 20.08 i am getting this error message -
 ./flexran_build.sh -e -r 5gnr_sub6 -m sd
make[1]: *** [source/phy/lib_dft_idft/CMakeFiles/libdft_idft.dir/all] Error 2
make: *** [all] Error 2
During DPDK setup (Option 39) - running this script - ./dpdk-setup.sh Getting the following error message -
/opt/dpdk-19.11/drivers/baseband/turbo_sw/bbdev_turbo_software.c(23): catastrophic error: cannot open source file "phy_turbo.h"
#include <phy_turbo.h>
compilation aborted for /opt/dpdk-19.11/drivers/baseband/turbo_sw/bbdev_turbo_software.c (code 4)
make[6]: *** [bbdev_turbo_software.o] Error 4
make[5]: *** [turbo_sw] Error 2
make[4]: *** [baseband] Error 2
make[3]: *** [drivers] Error 2
make[2]: *** [all] Error 2
make[1]: *** [pre_install] Error 2
make: *** [install] Error 2
RTE_TARGET exported as x86_64-native-linuxapp-icc
Please help.
Jose_V_Intel
Hello chella,
Thank you for posting on the Intel Community.
Based on the information that you provided and in order to better understand your issue please provide the following information:
  1. Please provide an Intel® System Support Utility report in .txt format. (make sure to select all the options before the scan)
  2. Provide a system report: https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html
  3. Is the system running any RAID configuration?
Please provide more details about the current issue.
Regards.
Jose V.
chella
Hi Jose,
Here is the information requested -
  1. Please provide an Intel® System Support Utility report in .txt format. (make sure to select all the options before the scan) Attahced.
    The server is linux and i am not able to see an option for that.
  3. Unable to produce this since there is no RAID setup on the server.
Sebastian_M_Intel
Hello chella,
Thank you for your reply.
I can see that your request is regarding FlexRAN.
I could see that you already posted the forum in the correct support place https://community.intel.com/t5/Intel-C-Compiler/Flexran-20-08-compile-issue/m-p/1250717
I will recommend you kindly wait for a response on the above-mentioned thread, we will proceed to close this one from our side.
Sebastian M
Intel Customer Support Technician
chella
Hi Team,
Please help on this. It has been nearly a month on this.
