Rapid Storage Technology
Intel® RST, RAID
reverse Intel Array 0000
Flemming1332
After seting up my computer I stupidly turned my second HDD into a backup drive via the Intel rapid drive. I now want to reverse the process since i do not have any access to that second drive anymore (It doesen't showin the menue and with irst it shows as Volume_0000). I allready tried to do it by starting the Computer via tha AHC1 SATA (in the Bios system) but then the computer wouldent start, also if i tried to start it in safe mode. If anyone has any tips i would be really happy.
n_scott_pearson
There are two possibilities. First, from the RST GUI, you should be able to remove the drive from the array. Second, either embedded in the motherboard's BIOS Setup program or (better, if it is supported) available separately via the entry of the <CTRL>-I key sequence during BIOS POST, you should be able to find a capability to remove drives from the array.
Hope this helps,
