Rapid Storage Technology
Intel® RST, RAID
2242 Discussions
Intel RST Unable to Detect the primary Drive When Installing a Windows Server 2022
Etr-EDM
Unable to Detect the primary Drive When Installing a Windows Server 2022 or any Windows at P360 Workstation (ThinkStation) has Intel Core i5 12500 3.0GHz / 6C / 12T & Intel Rapid Storage Technology Driver.
I'm looking for the correct drive to upload on another flash drive to install it before any OS installation. I contacted Intel on chat, and they suggest to post it here!
Any help?
Hugo_Intel
Hello Etr-EDM
Thank you for posting on the Intel Communities. I am sorry you are experiencing issues installing Windows on your system.
There should not be a need to install the ntel® RST driver in order for the system to recognize the drives, however, you can get the driver from your system manufacturer's website. I would also recommend following the installation guidelines from Lenovo for this issue.
Hugo O.
Etr-EDM
Hello, Hugo O.
As I mentioned above, when I install any Windows OS, I have to select the driver on which I will install the OS; at this step, I can't see the primary drive or any drive attached to the system board.
I went to the manufacturer's website, which is Lenovo, and the driver available is (Intel RST)
And this driver has no (.sys) file "when I extract it and upload it to another flash drive."
That's why I'm contacting the manufacturer of the chip Intel RST, to get the correct driver.
Hugo_Intel
Hello Etr-EDM
You can find the generic version of the driver in the following link:
Intel® Rapid Storage Technology Driver
You can use the Readme file attached with the installation instruction, section 6.3. Also, you can follow the instructions in the following article:
Unable to Find the Intel® Rapid Storage Technology (Intel® RST) Driver in Zip Format
Hugo O.
Hugo_Intel
Hello Etr-EDM
I hope you are doing fine.
Were you able to check the previous post?
Let us know if you still need assistance.
Best regards,
Hugo O.
Intel Customer Support Technician.
Hugo_Intel
Hello Etr-EDM
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
