Rapid Storage Technology
Intel® RST, RAID
2188 討論
why we need to add or remove only one SKP symbol in SKP OS even though four clock shifts are there
srilakshmi
新手
2,151 檢視
for 4096 TLP packet size there are four clock shifts that can occur for gen1 speed and X1 pipe width(   four clock cycles difference between recovered clock and local clock).
but the description in the below document is saying the following. (the PHY can add or remove one SKP symbol (PCIe* Mode at 2.5 or 5 GT/s),
PHY Interface for the PCI Express*, SATA, USB 3.2, DisplayPort*, and USB4 Architectures
August 2021 Revision 6.1
For the Nominal Half Full buffer model, the PHY is responsible for inserting or removing
SKP symbols, ordered sets, or ALIGNs in the received data stream to avoid elastic
buffer overflow or underflow. The PHY monitors the receive data stream, and when a
Skip ordered set or ALIGN is received, the PHY can add or remove one SKP symbol
(PCIe* Mode at 2.5 or 5 GT/s), four SKP symbols (PCIe* Mode at 8 GT/s, 16 GT/s, or
32 GT/s), one SKP ordered set (USB Mode at 5 GT/s), or one ALIGN from each SKP or
ALIGN as appropriate to manage its elastic buffer to keep the buffer as close to half full
as possible
could you please clarify what could be the reason for adding or removing only SKP symbol instead of four SKP symbols.
0 積分
4 回應
vij1
員工
2,081 檢視
Hello Srilakshmi,
Greetings for the day!
We are checking on this issue and will get back as soon as possible.
Vijay N.
vij1
員工
1,753 檢視
Hello Srilakshmi,
Please find the attached file for PHY Interface for the PCI Express*,SATA, USB 3.2, DisplayPort*, and USB4* Architectures
https://www.intel.com/content/www/us/en/content-details/643108/phy-interface-for-the-pci-express-pcie-sata-usb-3-2-displayport-and-usb4-architectures.html
Could you please confirm the processor details? Also, kindly share the details of the baseboard you are using.
Vijay N.
vij1
員工
1,726 檢視
Hello srilakshmi,
Greetings!
We hope this message finds you well. We are sending a follow up if you have any questions from the previous post. If so, please let us know.
Vijay N.
vij1
員工
1,695 檢視
Hello srilakshmi,
We have not received a reply from you , and as such, we will be closing your case.
If you want to continue support, please reply to this post and we will reopen your case or create a new one so that we can continue to support you.
Vijay N.
回覆
