Server Products
4845 Discussions
Сборка сервера
ДИсае
Добрый день!
Прошу помочь в сборке сервера. Хочу приобрести платформу R1304SPOSHBN и процессор Intel Xeon E3-1275v6 SR32A 3.80 GHz. Совместимы ли они?
Также уже имеется оперативная память Kingston KVR21E15D8/16 - 16 GB PC4 - 2133 CL15 ECC 288-Pin UDIMM , два модуля. Совместимы ли все эти компоненты?
Спасибо за ответы.
Hello Pal9111,
Thank you for reaching out Intel Customer Support, sorry for the delay on this one.
I Just checked your request and here are some tips you may want to considered:
The server system mentioned is already discontinued hence out of support and currently with limited access to documentation resources, I would recommend using R1304SPOSHBNR which is a refreshed version of it, mostly for easy of access to spare parts, documentation and support.
According to the documentation available neither the processor or the memory you mentioned are compatible with the system, please see attached the list of validated parts (proc and memory) for your system for tested compatible parts.
If further reference on this matter is needed please check:
ark.intel.com
https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_P4000S_R1000SPO_Family_Config_Guide.pdf Intel® Server S1200SP Family Configuration Guide
https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_TPS_AllSKU.PDF Intel® Server Board S1200SP Family Technical Product Specification
Please let me know if the information provided answers to your question or if further assistance is need.
Kenneth R.
Hello Pal9111,
ark.intel.com
Kenneth R.
ДИсае
Thanks for the answer! I already have a platform, now there is a choice in CPU and RAM. Can you answer this cpu is compatible with this platform?
https://ark.intel.com/products/97479/Intel-Xeon-Processor-E3-1270-v6-8M-Cache-3_80-GHz Intel® Xeon® Processor E3-1270 v6 (8M Cache, 3.80 GHz) Product Specifications or https://ark.intel.com/products/88174/Intel-Xeon-Processor-E3-1270-v5-8M-Cache-3_60-GHz Intel® Xeon® Processor E3-1270 v5 (8M Cache, 3.60 GHz) Product Specifications
I'm including the part list for SPOR for Processor and Memories on this message, you may want to take a look at that for reference. I would have liked to do the same for the SPO but that resource is no longer available due to system discontinuance, but going back to basics.
In the case of the board S1200SPO, it will support any E3-1200 V5 series processor, the refreshed version SP1200SPOR will support both V5 and V6 versions of the E3-1200 series. And the memories should always be DDR4 Unbuffered UDIMM.
A very important resource for this kind of set ups is the https://www.intel.com/content/dam/support/us/en/documents/server-products/S1200SP_P4000S_R1000SPO_Family_Config_Guide.pdf Spares and Configuration Guide, I hardly recommend you to check it up as it might provide information than it hasn't been considered and to have a more complete understanding of the platform, anyway you can always go safely with the information provided before.
Please let me know if this answers to your questions or if further assistance is required.
Kenneth R.
This goes as follow up, did you have the chance to check the information provided, is there anything else you may need help with?
Ken
ДИсае
Thank you very much. You helped me a lot. There are no more questions.
Good to hear,
I'm setting up this trend as closed if you need anything else now or in the future please contact us.
Ken
