Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4544 Discussions
1-5-4-4 Fallo de control de alimentación Energía buena aserción timeout-los sensores de la unidad de potencia reportan el control de potencia suave error offset. Este es la falla. Cual es la solución?
gDelG3
JoseH_Intel
Hello gDelG3, Thank you for joining the community Could you please tell what is the board or server chassis model in order to assist you in the best way possible? As you state this beep error code is usually related to power supply, so you want to test a good known power supply in order to first troubleshoot the issue. We will wait for your updates Regards. Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
JoseH_Intel
Hello gDelG3, I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. This thread will be marked as resolved automatically in the next 72 hours if no activity is received. Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
JoseH_Intel
Hello gDelG3, We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic. Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
