Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
A S2600CP base server does not boot up
Hello!
recently, I assembled a server based on S2600CP2 motherboard and Xeon E5 CPU. The system was working fine till today's morning (I was able
to install OracleVM on it and conduct some basic tests). Today, when I connected power cords to the chasiss, the fans started spinning, spun for about 2 seconds, then spun down. As long as the chasis was connected to power outlet, the cycle repeated with about 1 sec breaks.
I was able to login to BMC web ui without any problem (through AXXRMM4 external NIC). The log page was filling with
reports the power unit is powered off or being powered down - Asserted
reports the power unit is powered off or being powered down - Deasserted
entries and the system didn't react to power down requests.
Thinking I the PSU had failed, I replaced it with a 100% working one (taken from a working workstation) - it didn't change anything. I reconnected
all the power cables, clear BIOS with a jumper -- no changes.
Did I miss something or should just RMA the board?
Thanks in advance for any response,
Michał
Edward_Z_Intel
Did you check the System Event Log?
