After onboard lan (I350-AM2) celo test, linking 10m speed show fail
But i can connect to the internet on 10m/100m/1G ok.
Have idea what cause the test failed?
10. PCIE_slot1: Riser Card: a. SLOT1: E1G44HT/Intel Ethernet Server Adaper,Intel(R) 82580,1G,Quad Port,Copper PCIE*4 LAN Card (IN26309*1) b. SLOT2: Intel / I350-T2 / I350T2G1P20 / Intel Ethernet Server Adapter I350-T2 -Network adapter - PCI Express 2.1 (x4) low profile - 10Mb LAN, 100Mb LAN, Gigabit LAN -10Base-T, 100Base-TX, 1000Base-T RJ45 Copper (IN25109*1) c. SLOT3: E1G42HTG1P20 / N8104-145 / IntelR Ethernet Server Adapter I340-T2 / 1000BASE-T 2ch LAN PCI-Express(x4) (NEC0409*1) 11. PCIE_slot2: Riser Card: a. SLOT1: 82572GI/881983/Intel Pro/1000PT Server Adapter PCIEx1 (NEC No:N8104-126) For 9197 / LAN Card / NEC (IN25909*1) b. SLOT2: N8104-131 / PCI-E 2.0 x8, 2xSFP+ 10G CNA Card (2ch) (NEC3709*1) c. SLOT3: Intel Gigabit ET Dual Port Server Adapter/E1G42ETBLK/PCI Express 2.0 x4 (IN26409*1) 12. PCIE_slot3: Riser Card: a. SLOT1:N8104-133 / 1000BASE-T Adapter(4ch) (BRO0809*1) b. SLOT2:JL82576EB ES/Intel Protville-QT Gigabit ET Quad Port Server Adapter (IN23613*1)
Hello jayhsu,
To better assist you, can you please let us know more details:
- What is the model of the server where the ethernet adapter is embedded?
- Can you please share with us the link to the tool being used and the steps?
- Was it working before or is this the first time running the tool?
- Is this the only issue with the adapter (Test)? Does it work fine?
Adrian M.
Hello jayhsu,
Let me know if you need more assistance.
Adrian M.
Hello jayhsu,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
I am sorry for the late reply.
AMD platform, and use I350 on board.
Resource & Design Center Sign In (intel.com)
Step: celoe.efi /sendresp 1 2 /stopfail /loop 10
No, this was the first time.
Tested with OCP I350 card is okay.
