Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
Can E3-1230 v2 with s1200btsr power on with only 1* 4 pin power connector?
yka_c
since i want to put the system into a SFF case,
the power supply only with one 4 pin CPU connector.
but the s1200btsr have two 4 pin CPU connector on it
thanks
Edward_Z_Intel
Actually it requires an 8-pin CPU power connector. You should try to get an SSI-compliant power supply.
