I was wondering how much current is needed to power the Intel S2600TPR? I know that I need two Molex Minifit Jr connectors, each with 3 positive 12 volt pins and 3 ground pins.
Macrules34
Hello Nick Jane Jr,
In regards to your question, it is recommended between a 1600 to 2130 watt power supply for an Intel designed 2U server platform, for more additional information please check page 176 of the https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600TP_HNS2... power supply specification guidelines for the Intel S2600TPR page 148.
Sergio S.
I'm only powering one board do I still need 1600-2130watt power supply's? I'm not running this board in an intel chassis, rather a 3rd party chassis.
macrules34
Hello Macrules34,
You can use a power supply with a lower wattage; however, keep in consideration that in you are planning to add a more additional hardware the power supply might not support all these devices.
That is why we recommend using at least 1600 watt power supply.
Hello Macrules34,
We are following up your question and we would like to know if you need further assistance.
In case you need any more assistance, please feel free to contact us back.
Sergio S.
Hello Macrules34,
We are following up your question and we would like to know if you need further assistance. In case you need any more questions, please feel free to contact us back
Sergio S.
I need to know how much electrical current is needed for each lead to power the board?
Macrules34
Hello Macrules34,
Thank you for your reply, let me investigate on your question and I will contact you back.
Sergio S.
Hello Macrules34,
I just sent you a private message requesting some additional information in regards to your question.
Regards.
Hello Macrules34,
We recommend running thehttp://https://downloadcenter.intel.com/download/17732/Power-budget-tool power budget tool this tool might help you select the proper power supply for your board.
Sergio S.
Hello Macrules34,
I am hoping that I was able to answer all your questions, please contact us back in case you need further assistance.
Sergio S.
Hello Macrules34,
Please access this link:
Regards.
There are no downloads for the motherboard (S2600TPR) I was looking at.
The previous link was only a guide that might help you finding the proper power supply for your system depending on your system configuration. Even though the document mentions the S5500WB Server Board family, it can also help you finding a power supply the S2600TPR.
Now, as we mentioned on the previous thread, it is recommended between a 1600 to 2130 watt power supply for an Intel designed 2U server platform, feel free checking the https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600TP_HNS2... power supply specification guidelines for the Intel S2600TPR page 148.
Regards.
