Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4932 Discussions
EY82C628 SR3HF Intel Server Board S2600WFR
Jackiewang
Hi dear,
EY82C628 SR3HF
We used to test the part showing Revision ID: F4
But this time it shows F3.
Q1: Is there any difference between F4 and F3?
Q2: Any document to prove F4 and F3 ?
Q3: Revision ID F3 means SRID=3, and F4 means SRID 4 ?
Pls help to answer the questions to my mail: Jackie@hcn-elec.com
Thank you so much.
IntelSupport
Community Manager
Hello Jackiewang,
Regarding your question:
Q1: Yes there are difference between F3 and F4.
Q2: Yes, I will attach it on another post below
F4: Initializing and managing various platform components and services during the early boot process. PEIM module involved in the recovery process.
F3: System has loaded a firmware update capsule during the boot process, suggesting that a firmware update is either in progress or has been successfully applied.
Please let us know the outcome after you have checked it and will be happy to assist if any other troubleshooting required for this issue.
Thank you.
Hayat
IntelSupport
Community Manager
Hello Jackiewang,
Thank you.
Hayat
Hayat
Please go thru this pdf file below.
Thank you
IntelSupport
Community Manager
Hello Jackiewang,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Else if none, we will proceed to close the case.
Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
IntelSupport
Community Manager
Hello Jackie,
Thank You.
Hayat
IntelSupport
Community Manager
Hello Jackie,
This message is to inform you about the thread closure.
Once the thread is closed, it will no longer be monitored by Intel.
Kindly submit a new thread should you need further assistance. We will be more than glad to continue assisting you.
Hayat
