Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
Error While Installing Win2K in S5000VSA
I am trying to install Windows 2000 server With SP4 in S5000VSA board.
While loading all device drivers, before specifying SAS driver, it is giving an error as follows.
Unexpected error (0) occured at line 957 at D;ntosinstalloembios.bin
Details as follws:
Config : 2*Xeon @ 3.0 GHz / 4*2 GB DDR2/4* 146GB SAS h/s HDD
OS : WIndows 2000 advance server SP4
MBD BIOS : s5000.86b.11.00.0096 dt 01/13/2009.
Please help to resolve this issue.
Thanks in Advancs
Edward_Z_Intel
Windows 2000 is not validated on S5000VSA, so some driver may be missing or not working. Which driver are you installing? Did you use a tested USB floppy drive to load the driver? Check http://www.intel.com/support/motherboards/server/S5000VSA/sb/CS-022697.htm http://www.intel.com/support/motherboards/server/S5000VSA/sb/CS-022697.htm.
I highly recommend you to switch to Windows Server 2003.
Bear in mind that you are installing an OS which has not been validated on this board. So there wont be any drivers for W2k.
Here is the list on which OS have been validated:
http://www.intel.com/support/motherboards/server/S5000VSA/sb/CS-022698.htm
Try to disable Core Multi Processing in the Bios.
Go to Advanced >> Processor Configuration >> Disable Core Multi Processing
One more thing:
Can you try to install the OS as a non-raid configuration.
Configure SAS/SATA as RAID >> Disable.
All the best,
Kind Regards,
Aryan.
