Listed below are the Queries,
1. Are the System Boards ( Interface Cards) Similar to the ones in a 2U system Or are the HPC node based System Card's Different ?
2. Related to the HSBP of the 4 Node S2600BP - can you provide us with relevant Detailed information?
3. Are there Any Details Of the Chassis Drawing or Suppliers That we Can Get in touch with?
Awaiting for a Response.
ZAID
VEPL, INDIA
Hello ZAID,
Here is some of the information you have requested.
- 1. Are the System Boards ( Interface Cards) Similar to the ones in a 2U system Or are the HPC node based System Card's Different? Will use the standard 2U HCA, and you can find the compatible list for this card and additional parts on the https://ark.intel.com/products/93501/Intel-Compute-Module-HNS2600BPB Compatible Products List.
- 2. Related to the HSBP of the 4 Node S2600BP - can you provide us with relevant Detailed information? Will need a little more information on your question. But related to the HDD backplane it depends on the type of HDD that you will like to use. This information can also be found on the https://ark.intel.com/compare/96350,96349,93503,93498,93501,93499 Compare Intel® Product
- 3. Are there Any Details Of the Chassis Drawing or Suppliers That we Can Get in touch with? For additional information please see the Technical Product manual (https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/server-board-s2600bp-brief.pdf TPS):
Or also, the https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/HNS2600BP_S2600BNP_Integration_and_Service_Guide_V1_0.pdf Service Guide
If there is anything else we can help please feel free to ask.
Henry A.
Hello ZAID,
Henry A.
1. The Compatible Product List IS Not Linked. Request you to share the Right link.
2. Related to the HSBP -
a. would like to know Are There any reference designs for the BackPlane ( 4HDD / 12 HDD)
b. The HSBP connects all the 4 nodes are there any design App notes for the same ?
c. Are there any standard HPC 4 node HSBP part numbers From Intel ?
Hello ZAID,
I am sorry the links did not work.
Here are the links:
https://ark.intel.com/products/93501/Intel-Compute-Module-HNS2600BPB https://ark.intel.com/products/93501/Intel-Compute-Module-HNS2600BPB
I will get you the rest of the information on the HSBP as soon as possible, please allow me some time.
Henry A.
Hello ZAID,
Here are the links:
But the HSBP use it depends also on the Chasis use:
4 HDD
https://ark.intel.com/products/99740/Intel-Server-Chassis-H2204XXLRE https://ark.intel.com/products/99740/Intel-Server-Chassis-H2204XXLRE
12 HDD
https://ark.intel.com/products/98417/Intel-Server-Chassis-H2312XXLR3 https://ark.intel.com/products/98417/Intel-Server-Chassis-H2312XXLR3
Henry A.
Henry,
The details shared are informative but we are looking for the following details
1. HSBP part number and DXF, gerber Files . -
We need these details to Design our SYSTEM based on S2600BP.
2. Since the chassis is Intel design - we need access to the DXF or 3D file of the Chassis to design our PCB as per the mechanical suggested.
Hello ZAID,
I am afraid a part number for the HSBP is not available at this moment.
Depending on the number of HDD, that is the chassis that you will need to order:
4 HDD
12 HDD
Henry A.
Henry ,
So Is it safe to assume that the HSBP is a Part of the Chassis ?
In that case, We Need the details of the Chassis like the DXF to freeze our PCB based on S2600BP .
Can we Get the Details of the Chassis - DXF or 3D?
we need it for 4HDD. H2204XXLRE
Hello ZAID,
Yes the HSBP is part of the chasis, the reason why there to chasiss for the 4 and 12 HDD.
Right now this is the only information available for the public.
4 HDD
and this is the link for the Documents available:
https://www.intel.com/content/www/us/en/support/products/52763/server-products/server-chassis/2u-rack-server-chassis.html# collapse-object-4 https://www.intel.com/content/www/us/en/support/products/52763/server-products/server-chassis/2u-rack-server-chassis.html# collapse-object-4
I going to try and find more information for your request, but this normally the information available.
Henry A.
Henry
Will await for your response. Hope fully we can get More Information related to it.
In addition To System Cards, Do we have more details on the
1. Power Distribution Cards ?
2. PCIe- Riser Cards low Profile ?
3. Standard control panel ?
Details, Such as Gerber and DXF and Design files for these System cards Should help us .
Hello ZAID,
I am afraid that a detailed information on parts is normally managed only by Engineering. The only information is the spare parts and compatibility.
Henry A.
Hello ZAID,
Thank you for your time and patience. Like I mentioned before this information is only handled at the engineering level. But, I am still trying to get you some of the information. Could you please help me with this information:
- Is he designing a chassis based on an Intel Server Board?
- Is there a revenue that he will obtain from this?
Henry A.
Henry ,
We Appreciate you extended Support .
Relate to the information requested,
> Since We Have No access to the Chassis Drawing , We Would need The System Boards To complete the Design [ Mating of boards/ Cabling between boards ] etc. Designing a Chassis Is ruled out but modeling a 3D View of the PCB including system boards is Required.
> Revenue - I'm not pretty sure. Our Current focus Is Working on the proto-build.
Hello ZAID,
Thank you for your time and patience. I pass on the information provided and I will get back with you as soon as we some information.
Henry A.
Hello ZAID,
Thank you for your time and patience. With the information provided please contact our normal support team, you can do this either via Phone Call or web Ticket or chat.
For a phone call, you can dial 866-655-6565 Option # 2.
For Web Tickets or chat you can go to the following website:
https://www.intel.com/content/www/us/en/support/contact-support.html# @10 https://www.intel.com/content/www/us/en/support/contact-support.html# @10
Please add to the ticket that you have been speaking with community support and was recommended to contact them to verify your request and provide the information you had provided me:
> Since We Have No access to the Chassis Drawing, We Would need The System Boards To complete the Design [ Mating of boards/ Cabling between boards ] etc. Designing a Chassis Is ruled out but modeling a 3D View of the PCB including system boards is Required.
Henry A.
Hello ZAID,
I hope your are doing well!
Wanted to follow up and verify if you had the opportunity to contact Server Support Team to open a case for further help.
If there is anything else I can be of help.
Henry A.
Hello ZAID,
How did it go with the Server Support Team?
Henry A.
Related to the System Cards, for a Buchanan Pass System.
We Request,
> Access to Backplane System
> Access to Node Power Card.
Could You Provide us with more information on these System Card Designs ?
only the main board Ref Design is available on the Portal.
Hello ZAID,
https://www.intel.com/content/www/us/en/support/contact-support.html%23%4010 https://www.intel.com/content/www/us/en/support/contact-support.html# @10
Henry A.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
