Server Products
Data Center Products including boards, integrated systems, RAID Storage, and Intel® Xeon® Processors
5031 Discussions
How to clear TPM2.0 Provision data and Provision it again?
JimHsu_3166
I would like to re-provision TPM2.0 on D50DNP System.
But I encountered a problem, please see my below run step and picture.
Step1: Enable "Intel Virtualization"
Step2: Enable "Intel VT for Directed I/O"
Step3: Setting the Administrator Password
Step4: Disable "Intel TXT"
Step5: Disable SHA1 and Enable SHA256
Step6: Reboot system and Boot to "EFI Shell"
Step7: Unzip "TPM2ProvfilesCBnT-20230302.zip" to USB and Install to system
Step8: Run command   --->   Result : Empty Failed
  • Shell> ResetPlatformAuth.nsh SHA256 Example
So... How can I re-provision it?
  • BIOS: R01.01.0005
  • BMC: 1.81-0
  • CPLD: 4.6
  • FRU: 0.09
  • CPU: Sapphire Rapids 8480+
  • TPM FW: 15.23
  • TPM Chip: SLB 9672VU2.0
Sreelakshmi1
Hello Jim_Hsu,
Greetings for the day!
Thank you for posting in Intel community forum.
We are currently checking the details and we will reach out to you as soon as possible.
We request your patience during this time.
Sreelakshmi B
JimHsu_3166
Hi Sreelakshmi,
Thank you very much.
I look forward to your reply.
Jim Hsu
Sreelakshmi1
Hello Jim_Hsu,
Can you please confirm if TPM 2.0 is enabled in the BIOS? If it is, kindly provide a screenshot for further assistance.
Sreelakshmi B
JimHsu_3166
Hi Sreelakshmi,
Sure, Please refer to the picture below.
Jim Hsu
Sreelakshmi1
Hello Jim_Hsu, ,
Thank you for sharing the details. Please allow us some time to review the details and we will get back with an update shortly.
Sreelakshmi B
Sreelakshmi1
Hello JimHsu_3166,
We would like to inform you that as per the snapshot shared, we see that the TPM is not enabled.
Please refer the below user guide to configure TPM 2.0.
https://www.intel.com/content/dam/support/us/en/documents/server-products/Configuring_the_TPM_2.0.pdf
Sreelakshmi B
JimHsu_3166
Hi Sreelakshmi,
Sure, I have tried to enable TPM function and make sure the TPM is ready for use under Windows Server 2022.
But still cannot reset TPM provision data under EFI Shell.
Step4: Setting "TPM2 ClearControl(NO) + Clear"
Step5: Reboot system and Boot to "BIOS"
Step6: Enable "Intel TXT"
Step7: Disable SHA1 and Enable SHA256
Step8: Reboot system and Boot to "Windows Server 2022"
Step9: Run "tpm.msc" ---> The TPM is ready for use.
Step10: Reboot system and Boot to "EFI Shell"
Step11: Unzip "TPM2ProvfilesCBnT-20230302.zip" to USB and Install to system
Step12: Run command ---> Result : Empty Failed
Step13: Reboot system and Boot to "BIOS"
Step14: Disable "Intel TXT"
Step15: Setting "TPM2 ClearControl(NO) + Clear"
Step16: Reboot system and Boot to "EFI Shell"
Step17: Run command ---> Result : Empty Failed
Jim Shi
Sreelakshmi1
Hello JimHsu_3166,
Based on the snapshot analysis, the status indicates that TPM 2.0 is ready for use, with details such as TPM Manufacturer: IFX and Specification Version: 2.0. We would like to inform you that the snapshot information aligns with the article I shared earlier.
Please let us know if you have any specific issues or queries for which you are seeking a solution.
Sreelakshmi B
JimHsu_3166
Hi Sreelakshmi,
As the title says, do I have any way can re-provision it?
Jim Hsu
Sreelakshmi1
Hello JimHsu_3166,
Sreelakshmi B
Sreelakshmi1
Hello JimHsu_3166,
Since you need to clear TPM 2.0 provision data, kindly follow the below link and go to Section 3.4 Security Screen -> 8. TPM2 Operation to perform TPM 2.0 clear.
https://www.intel.com/content/dam/support/us/en/documents/server-products/intel-bios-setup-utility-user-guide-d50dnp-and-m50fcp.pdf
We would like to inform you that changing the TPM state in setup requires a hard reset for the new state to become effective.
Sreelakshmi B
Sreelakshmi1
Hello JimHsu_3166,
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Sreelakshmi B
JimHsu_3166
Hi Sreelakshmi,
But I still cannot provision TPM2 again after clear TPM2.0 under BIOS.
Could you kindly help to check you can re-provision TPM after clear TPM2.0 under BIOS?
Step1: Setting "TPM2 ClearControl(NO) + Clear"
Step2: Reboot system and Boot to "EFI Shell"
Step3: Run command #> ResetPlatformAuth.nsh SHA256 Example
If possible, could you please provide the successful picture?
Jim Hsu
Sreelakshmi1
Hello JimHsu_3166,
Sreelakshmi B
Sreelakshmi1
Hello JimHsu_3166,
Could you please run “MSFT_NVCI_Index.nsh CustomIndexForMSFT.iDef” command to create the NVCI Index (provisioning) and let us know the result.
The reset script is not mandatory. If the ownership was cleared by the BIOS Setup, there is nothing to reset.
Sreelakshmi B
Sreelakshmi1
Hello JimHsu_3166,
We are following up to find out if you were able to find the information we provided . Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Sreelakshmi B
Sreelakshmi1
Hello JimHsu_3166,
Good day!
We would like to inform you that we are closing this request as no response has been received from our previous follow-ups.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Sreelakshmi B
