Hey friends
I have to create an El Torreti Boot Disk to recovery my BIOS by using the Recovery Procedure
Its complicated and i tried to create one according to this tutorial http://support.microsoft.com/kb/167685/en-us http://support.microsoft.com/kb/167685/en-us but it didnt work
i have to create this stuff cuz the recovery procedure doesnt really work on usb devices because of an EFI Shell Bug
Can someone create an El Torreti Boot Disk? I have to include this Files.. http://www.solidfiles.com/d/fcc6487c06/IFlash32.rar http://www.solidfiles.com/d/fcc6487c06/IFlash32.rar
Thanks for reading
Which board is this for? Newer boards can boot off EFI and access a FAT32-formatted flash drive, and you don't have to create an El Torito boot CD.
its an Intel S5520HC
Yes it works on USB devices but there is an efi bug for usb i think and the system will get stuck
Take a look :
/servlet/JiveServlet/downloadImage/2-243676-237451/1200-900/20140721_171725.jpg https://communities.intel.com/servlet/JiveServlet/downloadImage/2-243676-237451/1200-900/20140721_171725.jpg
There should be an EFI device table on the top
Go into the BIOS and choose Exit > Load Default Values (or press F9). Power off, pull the plug from the wall for 20 seconds, then boot up and see if the EFI map shows the correct mapping now.
the bios has been 100% erased ^^ the recovery efi shell is bugged
there is no bios to reset at the moment but i tried to reset the cmos already
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
