From the downloadcenter, I got 5 different version of firmware packages.
But none of them has a IT firmware.
I turn to LSI website, and got the lastest firmware package of LSI 9211-8i.
Use the command sas2flash.efi -o -f 2118it.bin -b, then got a error message about can't flash a IT FW over current IR FW.
So, how to flash to IT FW?
I have solved.
Download p05 ver. firmware tool (sas2flash.efi), p20 ver. IT Firmware (2118it.bin) and p20 ver. BOOT ROM (mptsas2.rom) from avago/lsi website.
Copy sas2flash.efi, 2118it.bin and mptsas2.rom to a USB driver.
Reboot and enter EFI Shell.
FS0:>sas2flash.efi -o -f 2118it.bin
Then got a message about NVDATA mismatch, Y/N continue ?
Press Y to continue.
FS0:>sas2flash.efi -o -b mptsas2.rom
Reboot.
After initialize, Ctrl+C enter HBA's BIOS, the Adapter name change to LSI 9211-8i, and the FW Revision is 20.00.04.00-IT.
The firmware we recommend running can be found at the following website:
https://downloadcenter.intel.com/download/25110/SAS2-MPT-Firmware-and-OpROM-Update-Package-for-2U-4-Node-Systems https://downloadcenter.intel.com/download/25110/SAS2-MPT-Firmware-and-OpROM-Update-Package-for-2U-4-Node-Systems Select the second package listed (Intel_SAS2_FW_ph20pt2_public_2015.07.14.zip).
Instructions can be found here:
https://downloadmirror.intel.com/25110/eng/Readme_Intel_SAS2_FW_ph20pt2_public_2015.07.14.txt https://downloadmirror.intel.com/25110/eng/Readme_Intel_SAS2_FW_ph20pt2_public_2015.07.14.txt
I have download this package before, but don't find a IT firmware or instruction about how to turn IR to IT.
After runing rms2ll080.nsh, the result is IR firmware.
I have solved.
Reboot.
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
