Hello. There is a problem of strange disc indication in raid on the platform P4308CP4MHEN (https://ark.intel.com/products/56412/Intel-Server-System-P4308CP4MHEN). The m5015 raid controller is installed.
Configured 2 sas disks in raid 0 and 4 sas disks in raid 10.
In raid 0, the display on both disks is constant.
Periodically on the disks from raid 10 I observe a red indication as on the video.
At the same time the status shows Optimal.
Такая же проблема с индикацией была ранее когда был установлен раид-контроллер RS2BL040.
Hello, Jose. Thank you for the reply.
I spent replacing the raid controller precisely because of this. Then I changed the cable from the raid-controller to backplane. However, nothing changed in the disc display. Consequently, it’s not a third-party raid controller, but the rest of Intel’s hardware. What else can i check in this case?
Hello, Jose
There is nothing between the raid controller and the backplane, both cables go directly.
We have only one server, the backplane has nowhere to check.
Hello. I can't do it right now. Server is in use now. I will look for where I can move the virtual machines.
