We are presenting an issue with the C252 Chipset and the Kingston SSD brand specifically with the models: SA400S37/120G and SA400S37/240G.
When trying to make Raid 0, 1 always the raid is degraded. It was done with other SSD models and other brands and it worked. The tests were performed with Gigabyte MX33-BS0 and Asus P12R-M motherboards.
Any suggestion?
Hello Norion,
Thank you for posting on the Intel
- Does the issue occur if you try a different RAID level?
- Have you checked the compatibility between the drives and the motherboard?
- Brand and model of the other drives being tested.
Josue O.
Hello Norion,
We are following your thread and would like to know if you need further assistance.
Sergio S.
Hello Norion,
Sergio S.
Hello Norion,
Josue O.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
