Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4617 Discussions
Intel T5000PAL missing control panel pins!!!
JWadd1
I have an Intel board that only has silver dots where the 24 pin ssi control panel pins should be. How do I power this on??? Please help.
David_A_Intel
It is odd that it only has silver dots where the SSI Front Panel header is. Could you provide us with the PBA and Serial Number of the board?
JWadd1
Not sure where to find the PBA but here's some information from the board.
Server Board 5T000PAL
SN: IU12MP0145 RP
MAC1: 001E670A1288
Pictured is where the 24 pin ssi should be.
The PBA and serial number can be found on a white sticker. If your board does not have a white sticker with this information then we could be dealing with a pre-production system.
JWadd1
Found it.
BZAD10700760 PBA D78511-303
After checking the markings we are able to confirm that this board belongs to the TIGH2U system. Intel sold these units years ago to Kontron which is an OEM (Original Equipment Manufacturers) so we strongly recommend contacting them directly for further assistance:
800 480 0044
mailto:support@kontron.com support@kontron.com
