Ihave installed software stack on centos 7 for intel xeon phi 7120p , everything are succed , micctrl -s gives output mic0 ready ( online ) , my question is how to run this coreprocessor with the other 2 intel xeon e5-2603 v3 in the host server , so that ican manage phi as main processor .??
- Tags:
- Intel® Xeon®
Hi Rashko,
Our Intel® Xeon Phi™ Coprocessor 7120P as the name says it is a coprocessor device; it helps the system to run processes faster. It is necessary to install the operating system first using the server processors Intel® Xeon® Processor E5-2603 v3. Then, you can continue with the installation and configuration of the Intel® Xeon Phi™ Coprocessor 7120P.
The microcode and drivers for your coprocessor are available on the site below:
https://downloadcenter.intel.com/product/75799/Intel-Xeon-Phi-Coprocessor-7120P-16GB-1-238-GHz-61-core- Downloadcenter.intel.com
The https://software.intel.com/sites/default/files/article/373934/system-administration-for-the-intel-xeon-phi-coprocessor.pdf System Administration for the Intel® Xeon Phi™ Coprocessor
I recommend you to review the Article ID: 000020991, it provides useful information about the advantages of https://software.intel.com/en-us/articles/is-the-intel-xeon-phi-coprocessor-right-for-me Intel® Xeon Phi™ coprocessor
Mike C
Hi Rashko,
I am following your case, please let me know if I can assist you with anything else.
Mike C
Configuring how if this tool "xeon phi 7210P Coprocessor" mining crypto cpu script just like they do to super vga on eth coins.
example :
6* "xeon phi 7210P Coprocessor" ( 6 x 72 core = 432 ) core from board
Hi CPU'sMiner,
An impressive solution for graphics purposes; however, our Intel® Xeon Phi™ Coprocessor 7120P was developed for other kinds of applications.
Intel has released the new version of Intel® Xeon Phi™; now you can find them as processors instead of coprocessors supporting up to 72 Cores each. I suggest you the site below:
http://ark.intel.com/products/series/92650/Intel-Xeon-Phi-x200-Product-Family Intel® Xeon Phi™ x200 Product Family
Mike C
Hi Rashko,
I am wondering if you need anything else from my side. I will attempt to contact you again within 48 hours if we do not hear from you, the case will be closed.
Mike C
Hi Rashko,
I am following your last post. Let me know if you need anything else.
Mike C
![](/skins/images/7746D4550810124E96DD2FD9957552B1/responsive_peak/images/icon_anonymous_message.png)
Topic Options
