- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Tengo un lap Lap: dell Precision 7510 con un procesador
Intel Xeon cpu e3-1505M v5 @ 2.80Ghz.
NO puedo instalar Windows 11.
(P1). Puedo hacer Upgrade de procesador para cumplir con las condiciones de windows 11
y (P2)Que procesador seria su remplazo
Gracias anticipadas
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Roger5,
Thank you for posting in the community!
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our Server Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Norman S.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Roger5 ,
Greetings ~
Thank you for reaching Intel Community forum. Per your inquiry regarding the compatibility of your Intel Xeon E3-1505M v5 processor with Windows 11. According to Microsoft's official list of supported processors for Windows 11, the Intel Xeon E3-1505M v5 is not included https://learn.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
While some 7th generation processors and all 8th generation Intel processors are supported, the Xeon E3-1505M v5 does not meet these criteria
Additionally, since you are using a Dell Precision 7510, I recommend checking directly with Dell Support to see if they have any official guidance or BIOS updates that might help. Dell has a list of tested systems for Windows 11, and if your device is not included, they may suggest alternative solutions.
Thank you & Best Regards,
Devi_Intel
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Roger5 ,
Greetings ~
I am writing to follow up on the suggestion we previously recommended. Your feedback is important to us, and we want to ensure that everything is progressing smoothly on your end.
Devi_Intel
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Roger5,,
Greetings!
Kindly note that as we have not received any response from our previous follow-up, we will be closing this request.
You may receive an invitation to take a survey in a few days. We value your feedback and look forward to hearing about your support experience.
Thank You & Best Regards,
Ragulan_Intel
