Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Intel modular server - recent critical events
KBota
Masters,
We have an intel modular server with two host. Yesterday our Primary power supply gone, and our secondary power supply (an automatic aggregator) not started. While the maintainers try to fix the power supply the server stop and start few times.
Today when i logged in the modular server i see the following on dashborad --> in the system health box: red X on Power supply.
power supply 1 and 2 -->No power applied or power supply failure, potential cooling problem...
power suplly 3 -->ok
ps4-fan blank -->OK
But only the power 3 was plugged in. I don't now if this problem or not. The current watt load was 457W and stay in green zone. Anyway, i plugged in another power supply, but the required action still show "Install Power Supplies"
First question: May i have to initialize or have to do something, or enough just plug the power supply on?
At time when the primary power line was gone, the following event log was appeared:
1. HDD Cooling Zone Fault
Power Supply slot 1 has a defective fan and is contributing to a HDD Cooling Zone Fault.
But Power Supply 1 was not plugged in...so i don't understand why that was logged..?
2 PS Slot # 1 Fan # 1 Tach: Lower Critical sensor threshold asserted
Sensor: PS Slot # 1 Fan # 1 Tach: The sensor reading is too low
3. PS Slot # 2 Fan # 1 Tach: Lower Critical sensor threshold asserted
4. PS Slot # 1 Output Voltage: Lower Critical sensor threshold asserted
May i have to do something? No new events in the log. Today i clear.
Thank you !
To answer your question just plug the power supply, no need to restart the system. Basically the logs reported are describing the issue that happened and there is no need to be concerned about them since they are normal and expected.
